before the last august update I had no issue, but since I have permanent problem. I’ve seen that this problem were coming up many times, but now I’m effected too. When I finish my watch and turn off my TV then after it happens that the TV turns on without my influence. The timeframe is very different, when it turns on. WHat I have identified that I should not let the menu somewhere deep, for example in a library deeply in a file system folder, but should go up to the main menu. sometimes it helps, but many times doesn’t. Is there any solution? I disabled all the CEC, but does not realy help. It is realy annoying that in the middle of the night I realize that my TV is on and if I turn it of, does not mean that it won’t turn on again.
Thanks and regards
Provide Debug enabled logs they may show a reason
I’ve uploaded the following log:
https://paste.osmc.tv/fuxofujobe
What I’ve seen when the TV was turn on again withou my any action:
2021-09-18 22:12:04.002 T:801 DEBUG : SetConfigurationFromLibCEC - settings updated by libCEC
2021-09-18 22:12:12.432 T:1076 DEBUG : Thread JobWorker 1624330432 terminating (autodelete)
2021-09-18 22:12:12.461 T:1064 DEBUG : Thread JobWorker 1801961664 terminating (autodelete)
2021-09-18 22:12:12.939 T:801 DEBUG : SetConfigurationFromLibCEC - settings updated by libCEC
2021-09-18 22:12:44.928 T:801 DEBUG : PushCecKeypress - received key d8 duration 0
2021-09-18 22:12:44.937 T:600 DEBUG : HandleKey: menu (0xd8) pressed, action is Back
But please analyize the log. What can I do to avoid this automatic turn on?
thanks!
Hi, I did it from the settings menu/input, the only thing is the main CEC what I have left enabled. Else I would not be able top control. And I did it only after the problem occured.
What do you mean with main CEC?
Did you disable CEC under Settings - System - Input?
Yes. If I disable CEC there and control via phone then no error. Tv remains switched off. The log what I sent was with CEC enabled but only the first menu CEC enabled (in the config you have wrote too), and then the problem is there, TV turn on.
Is there anything I can do? Do you see anything in the log? My family don’t like controlling the tv with phone but none of us like to wake up at night many times to switch off the tv again amd agin.
Thank
Well as you wrote above what you see in the logs is that a key is pressed at the time of TV wake up.
So I really wonder if that was the time the TV woke up as you were playing a movie at that time?
But also from the logs it seems your power supply is not up to the job. Maybe a stable power supply to the Pi may also solve the problem
Sep 18 22:12:49 osmc kernel: Under-voltage detected! (0x00050005)
Sep 18 22:12:53 osmc kernel: Voltage normalised (0x00000000)
Ok, maybe my inserted log was missleading. I try to correct but please see the whole log.
So what I wanted to show (enhancing littlebit with more context):
This is in the log the last active entry (whether I switched off the TV or not I can’t judge, how I can figure out when exactly I pressed TV power off button? is there any log about it?)
2021-09-18 22:11:42.658 T:600 DEBUG : CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
This is the line and EXACT time, when the TV turns itself!
The button press and the other lines in the log, mostly about navigating to log stop and uploading.
The power supply under voltage is not a new issue. Same frequency was before and caused no problem. So deffinitly the problem was comming with the august update. If I turn off CEC then no TV automatic turn on, if only the first menu item is enabled: CEC enabled, then the problem appears.
thanks
Maybe try to upload logs via SSH to avoid CEC activity.
Maybe try to enable CEC component specific logging
I’ve created a new log with cec enabled, but I have run into the following problem:
osmc@osmc:~$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/
So no real url like I had list time. I rebooted many times, I tried this too:
osmc@osmc:~$ paste-log .kodi/temp/kodi.log
But as you can see no real luck. So how I can upload the new log? I tried manually upload on https://paste.osmc.tv , but Pressing the save: Something went wrong error message was comming. Any idea?
This sounded odd. Maybe a temporary problem with the upload server?
Can you try again and also check what does `ls -lah .kodi/temp/ gives you.
Can mean the logs are too big.
paste-log would inform if the logs are too big, wouldn’t it?
Hi Sam, fzinken,
It must be a temporary error as today I was able to upload with paste-log and the URL is generated as expected:
https://paste.osmc.tv/fiwelexela
Now it is too far to give the exact time when the TV was waken up, somewhen around 23:16. If it does not help today I try to reproduce. Hope you will see something in the log.
thanks
By the way, if you check the previous message you can see that paste-log was giving back wrong answer, no too big size or anything else.
regads
Yes, therefore I told @sam_nazarko it must have been a temporary issue and not size too big
taszilo19:
You started playback of a movie which woke up the TV, I am still not sure about the actual issue
2021-09-25 23:16:19.438 T:752 DEBUG <general>: PushCecKeypress - received key b duration 75
2021-09-25 23:16:19.438 T:752 DEBUG <general>: CecLogMessage - >> TV (0) -> Playback 1 (4): user control release (45)
2021-09-25 23:16:19.438 T:830 DEBUG <general>: CDVDAudio::Flush - flush audio stream
2021-09-25 23:16:19.439 T:723 DEBUG <general>: CActiveAE::DiscardStream - audio stream deleted
2021-09-25 23:16:19.439 T:723 DEBUG <general>: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
2021-09-25 23:16:19.440 T:830 INFO <general>: Skipped 2 duplicate messages..
2021-09-25 23:16:19.440 T:830 INFO <general>: Deleting audio codec
2021-09-25 23:16:19.441 T:830 INFO <general>: Closing stream player 2
2021-09-25 23:16:19.441 T:830 INFO <general>: waiting for video thread to exit
2021-09-25 23:16:19.442 T:724 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-09-25 23:16:19.464 T:832 WARNING <general>: OutputPicture - timeout waiting for buffer
2021-09-25 23:16:19.464 T:832 INFO <general>: thread end: video_thread
2021-09-25 23:16:19.465 T:832 DEBUG <general>: Thread VideoPlayerVideo 1496314048 terminating
2021-09-25 23:16:19.466 T:830 INFO <general>: deleting video codec
2021-09-25 23:16:19.476 T:835 DEBUG <general>: Thread JobWorker start, auto delete: true
2021-09-25 23:16:19.478 T:830 DEBUG <general>: Thread VideoPlayer 1520320704 terminating
2021-09-25 23:16:19.478 T:586 INFO <general>: VideoPlayer: finished waiting
2021-09-25 23:16:19.478 T:586 INFO <general>: CVideoPlayer::CloseFile()
2021-09-25 23:16:19.478 T:586 INFO <general>: VideoPlayer: waiting for threads to exit
2021-09-25 23:16:19.482 T:586 DEBUG <general>: Radio UECP (RDS) Processor - delete ~CDVDRadioRDSData
2021-09-25 23:16:19.488 T:835 INFO <general>: Deleting settings information for files /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S03.Droid.Tales/LEGO.Star.Wars.S03E03.Droid.Tales.WEB-DL.x264.Hun-Krissz.mp4
2021-09-25 23:16:19.490 T:836 DEBUG <general>: Thread JobWorker start, auto delete: true
2021-09-25 23:16:19.491 T:836 DEBUG <general>: DoWork - Saving file state for video item /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S03.Droid.Tales/LEGO.Star.Wars.S03E03.Droid.Tales.WEB-DL.x264.Hun-Krissz.mp4
2021-09-25 23:16:19.638 T:724 DEBUG <general>: CActiveAESink::OpenSink - trying to open device ALSA:@
2021-09-25 23:16:19.638 T:724 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "@"
2021-09-25 23:16:19.651 T:724 INFO <general>: CAESinkALSA::Initialize - Opened device "sysdefault"
2021-09-25 23:16:19.654 T:724 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-09-25 23:16:19.655 T:724 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE3
2021-09-25 23:16:19.655 T:724 DEBUG <general>: CAESinkALSA::InitializeHW - Request: periodSize 2205, bufferSize 8820
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CAESinkALSA::InitializeHW - Got: periodSize 2205, bufferSize 8820
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: FL FR)
2021-09-25 23:16:19.659 T:724 DEBUG <general>: CActiveAESink::OpenSink - ALSA Initialized:
2021-09-25 23:16:19.659 T:724 DEBUG <general>: Output Device : Default (vc4-hdmi MAI PCM vc4-hdmi-hifi-0)
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Sample Rate : 44100
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Sample Format : AE_FMT_S24NE3
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Channel Count : 2
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Channel Layout: FL, FR
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Frames : 2205
2021-09-25 23:16:19.660 T:724 DEBUG <general>: Frame Size : 6
2021-09-25 23:16:19.665 T:723 DEBUG <general>: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
2021-09-25 23:16:19.788 T:835 DEBUG <general>: Skipped 1 duplicate messages..
2021-09-25 23:16:19.788 T:835 DEBUG <general>: OnPlayBackStopped: CApplication::OnPlayBackStopped
2021-09-25 23:16:19.795 T:586 DEBUG <general>: CGUIWindowManager::PreviousWindow: Deactivate
2021-09-25 23:16:19.796 T:586 DEBUG <general>: ------ Window Deinit (VideoOSD.xml) ------
2021-09-25 23:16:19.796 T:586 DEBUG <general>: ------ Window Deinit (VideoFullScreen.xml) ------
2021-09-25 23:16:19.824 T:586 DEBUG <general>: CGUIWindowManager::PreviousWindow: Activate new
2021-09-25 23:16:19.837 T:586 DEBUG <general>: ------ Window Init (MyVideoNav.xml) ------
2021-09-25 23:16:19.841 T:586 DEBUG <general>: CGUIMediaWindow::GetDirectory (/mnt/data-share/Cartoons_Series/Lego.Star.Wars/S03.Droid.Tales/)
2021-09-25 23:16:19.841 T:586 DEBUG <general>: ParentPath = [/mnt/data-share/Cartoons_Series/Lego.Star.Wars/S03.Droid.Tales/]
2021-09-25 23:16:19.853 T:837 DEBUG <general>: Thread BackgroundLoader start, auto delete: false
2021-09-25 23:16:19.880 T:586 DEBUG <general>: ffmpeg[(nil)X]: [image2] Custom AVIOContext makes no sense and will be ignored with AVFMT_NOFILE format.
2021-09-25 23:16:19.906 T:837 DEBUG <general>: Thread BackgroundLoader 1561137344 terminating
2021-09-25 23:16:20.257 T:586 DEBUG <general>: ffmpeg[(nil)X]: [image2] Custom AVIOContext makes no sense and will be ignored with AVFMT_NOFILE format.
2021-09-25 23:16:20.342 T:836 DEBUG <general>: ffmpeg[0x719e7138X]: [image2] Custom AVIOContext makes no sense and will be ignored with AVFMT_NOFILE format.
2021-09-25 23:16:20.368 T:586 DEBUG <general>: ------ Window Deinit (DialogSeekBar.xml) ------
2021-09-25 23:16:20.451 T:586 DEBUG <general>: CVideoLayerBridgeDRMPRIME::Disable - setting connector colorspace to Default
2021-09-25 23:16:20.451 T:586 DEBUG <general>: CDRMUtils::DrmFbDestroyCallback - removing framebuffer: 208
2021-09-25 23:16:20.451 T:586 DEBUG <general>: CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
2021-09-25 23:16:20.502 T:586 DEBUG <general>: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------
2021-09-25 23:16:20.503 T:586 DEBUG <general>: CDRMUtils::DrmFbDestroyCallback - removing framebuffer: 207
2021-09-25 23:16:20.503 T:586 DEBUG <general>: CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
2021-09-25 23:16:20.540 T:586 DEBUG <general>: CDRMUtils::DrmFbDestroyCallback - removing framebuffer: 206
2021-09-25 23:16:20.540 T:586 DEBUG <general>: CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
2021-09-25 23:16:20.585 T:586 DEBUG <general>: CDRMUtils::DrmFbDestroyCallback - removing framebuffer: 209
2021-09-25 23:16:20.585 T:586 DEBUG <general>: CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
2021-09-25 23:16:22.409 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=8 addr=0f opcode=a0
2021-09-25 23:16:22.409 T:752 DEBUG <general>: CecLogMessage - >> 0f:a0:00:80:45:20:01:10
2021-09-25 23:16:22.409 T:752 DEBUG <general>: CecLogMessage - TV (0): power status changed from 'on' to 'standby'
2021-09-25 23:16:22.409 T:752 DEBUG <general>: CecLogMessage - >> TV (0) -> Broadcast (F): vendor command with id (A0)
2021-09-25 23:16:22.479 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=2 addr=0f opcode=36
2021-09-25 23:16:22.479 T:752 DEBUG <general>: CecLogMessage - >> 0f:36
2021-09-25 23:16:22.479 T:752 DEBUG <general>: CecLogMessage - >> TV (0) -> Broadcast (F): standby (36)
2021-09-25 23:16:23.121 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=2 addr=0f opcode=36
2021-09-25 23:16:23.121 T:752 DEBUG <general>: CecLogMessage - >> 0f:36
2021-09-25 23:16:40.655 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
2021-09-25 23:16:42.673 T:752 DEBUG <general>: CecLogMessage - changing physical address to FFFF
2021-09-25 23:16:42.673 T:752 DEBUG <general>: CecLogMessage - SetDevicePhysicalAddress - not setting invalid physical address ffff
2021-09-25 23:16:42.673 T:752 DEBUG <general>: SetConfigurationFromLibCEC - settings updated by libCEC
2021-09-25 23:16:50.341 T:835 DEBUG <general>: DoWork - trying to extract thumb from video file /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E04.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:50.372 T:836 DEBUG <general>: Thread JobWorker 1520320704 terminating (autodelete)
2021-09-25 23:16:50.862 T:835 DEBUG <general>: Open - probing detected format [matroska,webm]
2021-09-25 23:16:50.869 T:835 DEBUG <general>: Open - avformat_find_stream_info starting
2021-09-25 23:16:50.927 T:835 DEBUG <general>: Open - av_find_stream_info finished
2021-09-25 23:16:50.928 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=1000
2021-09-25 23:16:50.929 T:835 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 0
2021-09-25 23:16:50.929 T:835 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 1
2021-09-25 23:16:50.929 T:835 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 2
2021-09-25 23:16:50.929 T:835 DEBUG <general>: ScanForExternalSubtitles: Searching for subtitles...
2021-09-25 23:16:50.930 T:835 DEBUG <general>: ScanForExternalSubtitles: END (total time: 1 ms)
2021-09-25 23:16:50.931 T:835 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2021-09-25 23:16:50.932 T:835 DEBUG <general>: CDVDVideoCodecFFmpeg - Updated codec: ff-h264
2021-09-25 23:16:50.932 T:835 DEBUG <general>: ExtractThumb - seeking to pos 93774ms (total: 281323ms) in /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E04.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:50.934 T:835 DEBUG <general>: SeekTime - seek ended up on time 92134
2021-09-25 23:16:51.062 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0010 phys_addr=1000
2021-09-25 23:16:51.062 T:752 DEBUG <general>: CecLogMessage - changing physical address to 1000
2021-09-25 23:16:51.062 T:752 DEBUG <general>: CecLogMessage - marking Playback 1 (4) as inactive source
2021-09-25 23:16:51.062 T:752 DEBUG <general>: CecLogMessage - >> source deactivated: Playback 1 (4)
2021-09-25 23:16:51.078 T:752 DEBUG <general>: CecLogMessage - << Playback 1 (4) -> broadcast (F): physical address 1000
2021-09-25 23:16:51.078 T:752 DEBUG <general>: CecLogMessage - << 4f:84:10:00:04
2021-09-25 23:16:51.085 T:835 DEBUG <general>: cached image 'special://masterprofile/Thumbnails/6/6c8f9ab6.jpg' size 540x303
2021-09-25 23:16:51.134 T:835 DEBUG <general>: ExtractThumb - measured 793 ms to extract thumb from file </mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E04.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv> in 17 packets.
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=5 addr=4f opcode=84
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - making Playback 1 (4) the active source
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - TV (0): power status changed from 'standby' to 'in transition from standby to on'
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - >> source activated: Playback 1 (4)
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - sending active source message for 'Playback 1'
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - << powering on 'TV' (0)
2021-09-25 23:16:51.474 T:752 DEBUG <general>: CecLogMessage - << 40:04
2021-09-25 23:16:51.540 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=40 opcode=04
2021-09-25 23:16:51.541 T:752 DEBUG <general>: CecLogMessage - << requesting power status of 'Playback 1' (0)
2021-09-25 23:16:51.541 T:752 DEBUG <general>: CecLogMessage - << 40:8f
2021-09-25 23:16:51.607 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=40 opcode=8f
2021-09-25 23:16:51.608 T:752 DEBUG <general>: CecLogMessage - source switch is currently not allowed by command handler
2021-09-25 23:16:51.608 T:752 DEBUG <general>: CecLogMessage - failed to make 'Playback 1' the active source. will retry later
2021-09-25 23:16:51.608 T:752 DEBUG <general>: SetConfigurationFromLibCEC - settings updated by libCEC
2021-09-25 23:16:51.658 T:841 DEBUG <general>: Thread JobWorker start, auto delete: true
2021-09-25 23:16:51.658 T:841 DEBUG <general>: DoWork - trying to extract thumb from video file /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E02.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:51.670 T:841 DEBUG <general>: Open - probing detected format [matroska,webm]
2021-09-25 23:16:51.678 T:841 DEBUG <general>: Open - avformat_find_stream_info starting
2021-09-25 23:16:51.717 T:841 DEBUG <general>: Open - av_find_stream_info finished
2021-09-25 23:16:51.718 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 0
2021-09-25 23:16:51.718 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 1
2021-09-25 23:16:51.719 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 2
2021-09-25 23:16:51.719 T:841 DEBUG <general>: ScanForExternalSubtitles: Searching for subtitles...
2021-09-25 23:16:51.720 T:841 DEBUG <general>: ScanForExternalSubtitles: END (total time: 1 ms)
2021-09-25 23:16:51.720 T:841 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2021-09-25 23:16:51.721 T:841 DEBUG <general>: CDVDVideoCodecFFmpeg - Updated codec: ff-h264
2021-09-25 23:16:51.721 T:841 DEBUG <general>: ExtractThumb - seeking to pos 73045ms (total: 219136ms) in /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E02.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:51.724 T:841 DEBUG <general>: SeekTime - seek ended up on time 72739
2021-09-25 23:16:51.821 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=8 addr=0f opcode=a0
2021-09-25 23:16:51.821 T:752 DEBUG <general>: CecLogMessage - >> 0f:a0:00:80:45:20:00:00
2021-09-25 23:16:51.821 T:752 DEBUG <general>: CecLogMessage - TV (0): power status changed from 'in transition from standby to on' to 'on'
2021-09-25 23:16:51.821 T:752 DEBUG <general>: CecLogMessage - << 40:89:10:02:ff:ff:00:05:05:45:55:5c:58:32
2021-09-25 23:16:51.821 T:752 DEBUG <general>: CecLogMessage - >> TV (0) -> Broadcast (F): vendor command with id (A0)
2021-09-25 23:16:51.911 T:841 DEBUG <general>: cached image 'special://masterprofile/Thumbnails/0/09d69986.jpg' size 540x303
2021-09-25 23:16:51.962 T:841 DEBUG <general>: ExtractThumb - measured 304 ms to extract thumb from file </mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E02.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv> in 17 packets.
2021-09-25 23:16:52.172 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=14 addr=40 opcode=89
2021-09-25 23:16:52.172 T:752 DEBUG <general>: CecLogMessage - << Playback 1 (4) -> broadcast (F): active source (1000)
2021-09-25 23:16:52.172 T:752 DEBUG <general>: CecLogMessage - << 4f:82:10:00
2021-09-25 23:16:52.287 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=4 addr=4f opcode=82
2021-09-25 23:16:52.381 T:752 DEBUG <general>: CecLogMessage - CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=3 addr=04 opcode=90
2021-09-25 23:16:52.381 T:752 DEBUG <general>: CecLogMessage - >> 04:90:02
2021-09-25 23:16:52.381 T:752 DEBUG <general>: CecLogMessage - TV (0): power status changed from 'on' to 'in transition from standby to on'
2021-09-25 23:16:52.381 T:752 DEBUG <general>: CecLogMessage - >> TV (0) -> Playback 1 (4): report power status (90)
2021-09-25 23:16:52.986 T:841 DEBUG <general>: DoWork - trying to extract thumb from video file /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E01.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:52.994 T:841 DEBUG <general>: Open - probing detected format [matroska,webm]
2021-09-25 23:16:53.008 T:841 DEBUG <general>: Open - avformat_find_stream_info starting
2021-09-25 23:16:53.062 T:841 DEBUG <general>: Open - av_find_stream_info finished
2021-09-25 23:16:53.062 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 0
2021-09-25 23:16:53.063 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 1
2021-09-25 23:16:53.063 T:841 DEBUG <general>: CDVDDemuxFFmpeg::AddStream ID: 2
2021-09-25 23:16:53.063 T:841 DEBUG <general>: ScanForExternalSubtitles: Searching for subtitles...
2021-09-25 23:16:53.064 T:841 DEBUG <general>: ScanForExternalSubtitles: END (total time: 1 ms)
2021-09-25 23:16:53.064 T:841 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2021-09-25 23:16:53.065 T:841 DEBUG <general>: CDVDVideoCodecFFmpeg - Updated codec: ff-h264
2021-09-25 23:16:53.065 T:841 DEBUG <general>: ExtractThumb - seeking to pos 135712ms (total: 407136ms) in /mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E01.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv
2021-09-25 23:16:53.068 T:841 DEBUG <general>: SeekTime - seek ended up on time 135302
2021-09-25 23:16:53.241 T:841 DEBUG <general>: cached image 'special://masterprofile/Thumbnails/3/3b7a181e.jpg' size 540x303
2021-09-25 23:16:53.293 T:841 DEBUG <general>: ExtractThumb - measured 307 ms to extract thumb from file </mnt/data-share/Cartoons_Series/Lego.Star.Wars/S04.The.Resistance.Rises/LEGO.Star.Wars.S04E01.The.Resistance.Rises.720p.WEBRip.x264.HUN.ENG-H73.mkv> in 17 packets.
2021-09-25 23:16:53.381 T:752 DEBUG <general>: CecLogMessage - << powering on 'TV' (0)
The issue that I do NOT start to play any movie after I switched off the TV! So what you should see in the log, I’m not sure that everything is there, but today evening I try to recreate the log and upload, maybe this playing around the upload added more things which missleades, but the exact reproduction steps which should be somehow visible in the log, do everything with TV remote control, no android, no web client:
start to play a movie, scroll in it, pause, play again so normal usages.
press STOP, but do no navigate away from the folder where the movie files is
press power off on TV remote control
wait sometime, sitting in the chair, do not press anything on TV remote or any other client
The issue: TV turns On
If you do not see it from the log, then I need littlehelp, what to turn on in log or what should I enter here. If you see in the log that the movie play powers the TV, then some kind of automatizm does this, but I have no clue, what.
taszilo19:
Well mark the timestamps of that steps. Also maybe wait a minute after you stop the video before your switch off the TV.
Also you could connect via SSH to OSMC and run cec-client -m to see what is happening.
Also can you post a screen shot of the OSMC CEC config screen.
BTW, which TV do you have? Is it directly connected or via AVR?
In the logs it seems like that Kodi when extracting the thumbnail for the Video is indicating the active source.
