Well the best source of information you can find here DVB-S USB Devices - LinuxTVWiki
I am using Bus 001 Device 004: ID 07ca:850a AVerMedia Technologies, Inc. AverTV Volar Black HD (A850) which works well
I would still like to hear from someone who has actually got it working in HD using pi1, 2 or 3 as server, and can point to a USB device I can find on Amazon (so many seem to be under different names). Cheers.
I wonder if there is enough demand for us to warrant an official just-works OSMC DVB-T2 USB dongle for users. That would require a large minimal order and would be quite an outlay.
I’m using Astrometa DVB-T2 usb stick and it’s working perfectly.
There was an issue with AAC audio. I needed to build tvheadend from master branch to make it work.
I have three different cheap tuners all based on the RTL2832u chipset There were some problems with this in previous kernel versions, however mine are all working with the latest kernel.
Hi all, thanks for the tips. Just to be clear - does anyone successfully get Freeview in HD? (using the Astrometa, or the RTL2832u for example). Is HD (Freeview) possible using TVheadend in OSMC? Andrew
Hi. I am not running TVHeadend on the RasPi, but on an old x86-64 Xeon rack server running Ubuntu 15.10.
I have 3 tuners running with TVHeadend:
USB Realtek RTL2838 DVB-T (0bda:2838)
USB Astrometa DVB-T2 (15f4:0131)
PCI Technisat SkyStar2 DVB-S2
Of course I can only get HD on the Astrometa and the Technisat.
Now it wasn’t plain sailing with the Astrometa, I had to recompile the linuxtv media tree with Antiis drivers. It looks like Ubuntu will have these drivers as part of the new 16.04 LTS release. However, I’m pretty sure you will have to compile them for Kodi on your Pi for some time to come!
But when it works it’s great - all the Freeview HD channels work no problem. Recording and playback too.
However, with OSMC on the Pi’s I have been getting audio synch problems since all releases after 2016.01. Sadly they have been getting worse not better with each update to OSMC and the last version 2016.04 is terrible. Audio and Video can be 10 seconds out of synch!! I think this is something to do with the HTS Client included with OSMC. I’ve upgraded TVHeadend on the server to the latest and the problem is still there.
This synch problem affects all tuners not just the DVB-T2. I’m going to make a seperate post on the issue but have been surprised nobody else seems to have reported it.
I have a Raspberry pi OSMC and ubuntu NUC with Leadtek WinFast DTV Dongle Dual USB TV Tuner, work fine, recording etc. Also have 2 PlayTV PS3 tuners on Xpenology/HP microserver/tvheadend
Some years ago I purchased the cheapest DVB-T from eBay, about £6
Search for RTL2832U R820T
It was a gamble!
It had a dongle, aerial , remote , CD
The CD had a windows program that had “DEMO” across the screen, rubbish.
The aerial was useless.
The remote worked.
So I put the lot in my top drawer.
Some while later I got a Raspberry Pi 2
Fished the dongle from my top drawer.
Plugged in and the Pi saw it, using lsusb. Plugged in a proper roof mounted aerial.
Installed TVheadend and that also worked out the box, bit fiddly to set up.
So I now have TV,Radio streamed around my home net, brilliant.
Jim
It was a long journey when I started a year ago, but my August DVB-T210 (Ver 2.0) now works fine on Pi2 with TVheadend. All the kernel modules and firmware files you need are now included in the latest OSMC distribution, I believe. The last time I did a clean install only two firmware files were missing but I think Sam’s fixed that. You need the hardware decoding licence for normal MPEG2 channels but HD is fine. And don’t expect an indoor aerial to work unless you can see the transmitter mast.
Just occasionally, if I leave a channel tuned in all night I wake up to a freeze, but I’ve no idea whether that’s the tuner or the Pi.
I am using simultaneously 3 pieces of CSL-USB-DVBT purchased at amazon.de
At the very early project, I used one of them directly at a Raspi1 B, 6 weeks or so. Was okay for recording, never used live TV with Raspi1. Later, I moved the DVB-T stick to an xubuntu 14.04 LTS (x86) nd increased the number of sticks to 3. Works quite good for recording, still not used live TV with (in between 3) Raspi1 B based kodi players.
Again later, I upgraded one player to Pi 2B and frequently I’m using the live TV now (SD resolution).
my 1st setup:
Room Antenna → CSL-DVBT → Raspi1B → HDMI TV
my current setup
Room Antenna under the roof top → Antenna amplifier → loooong cable →
→ Antenna Splitter 1-to-8 → 3x CSL-DVBT → x86 linux with tvheadend + 2TB hdd → 100 Mbit ethernet →
switches → 2x Raspi 1B + 1x Raspi2B → HDMI/SPDIF-Splitter → TVs and SPDIF sound systems
my future setup, planned for autumn:
replace DVB-T with DVB-S or replace DVB-T with DVB-T2.H265 (or a mix of both)
upgrade all Raspi1 to Raspi2
2x 4TB hdd
thanks everyone for the great response. I’ll have a look at this at the weekend when I have some time. will let you know if I have some success.,cheers. Andrew
Hi, The price seems good. Can you confirm this is the dongle you have? http://www.amazon.com/RTL-SDR-DVB-T-Stick-RTL2832U-R820T/dp/B00C37AZXK
Can you tell me what do you mean with “bit fiddly to set up”. Do you have the procedure you followed for setup?
Can you also clarify how did you do this “So I now have TV,Radio streamed around my home net, brilliant”.
How do you stream them?
What about the input of antenna? Which type of input does it have? Can you post a photo?
