TVHeadend, First 15-20secs
Ok so when I schedule a recording, the first 15-20secs might have 1-3 picture frames but has audio in background.
I tried the .ts file from server to laptop playing on VLC and media player and there is no lagging of frames
So I linked the vero4k to the .ts directory to play through video and not associated with TV section. and it does the same, also tried a file with a higher bitrate in same folder and this played fine.
So at least i know networks fine, but what else could cause this?
Is this an MPEG2 stream? We are probably waiting for a key frame before displaying anything.
hi sam,
its just a recording of HD channel that records to a .ts file
I would need some more information (MediaInfo, debug log and a sample) to look in to this
No probs, ive set it to record songs of praise, i`ll check its doing it on that, then just let me know, where to get the data you want and where i can upload the video for you to check
I had this exact same issue, and for me it was fixed by the following commit which is part of the next release:
Cheers,
Sam, is there a patch to update them files via ssh?
Hopefully the issue is now addressed with the following commit:
  1. Login via the command line
  2. Edit the file /etc/apt/sources.list
  3. Add the following line: deb http://apt.osmc.tv stretch-devel main
  4. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  5. Your system should have have received the update.
Cheers Sam and jahutchi
Perfect opens file instantly no jutters
Can i remove the bellow now?
  1. Edit the file /etc/apt/sources.list
  2. Remove the following line: deb http://apt.osmc.tv stretch-devel main
Yes
