I’m using OSMC (Kodi 16.1) on a RasberryPi 3. In general I am extremely pleased and everything works very smooth. However, for a few days now I try to get LiveTV working. I use a DVBSky 960 DVB-S2 receiver connected directly to the Pi’s USB port. I’ve installed TVHeadend from the App store (version 4.0) and enabled the Tvheadend HTSP Client under MyAddons. The TVHeadend server is up and running and I can stream LiveTV to other devices (iPhone, Macbook, iPad, etc.) through VLC but also KODI installed on those devices.
However, on the Pi3 itself I’m getting the following error message after booting:
TVHEADEND HTSP CLIENT connection lost. Needless to say, I use the same login credentials on all devices.
On the Pi3 I’ve tried different IP addresses (the “external” IP of the Pi3 i.e. 192.168.0.4, localhost i.e. 127.0.0.1). I’ve created a second user on the TVHeadend server with no login/password as suggested in another post on this forum but none of this seems to help.
The log shows this error message:
11.795101 T:1693447152 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 127.0.0.1:9982.
Looks good, so suggest to enable debug logging and then once more check the configuration with username/password. Use 127.0.0.1 as the IP
If still failed upload the debug logs
Hm - will try and connect the receiver to a powered USB hub (is that what you mean - that the USB port is not providing sufficient power?). It’s weird though that using any other device I never have a problem - that seems too much of a coincidence to be true
Anyway, will try.
Well I don’t mean that exactly. I just believe as it seems to work sometimes. That your Pi is not getting enough power and therefore in the moment you try to access PVR from the same Pi you get power drops.
Just a potential source as no other explanation
Since I’m in a very close case (I’ve a Volar Green HD TNT Tuner USB stick instead ) could you tell me if you find a solution, a piece of solution or if it is illusory to want to use an TNT USB stick to play HD TV on a Pi3 ?
Fzinken … I’ve restarted my pi and connected the tuner usb, as seen at the end of the dmesg log : http://paste.osmc.io/puxesemodi
And the lsusb output:
Bus 001 Device 005: ID 13fd:1840 Initio Corporation INIC-1608 SATA bridge
Bus 001 Device 004: ID 1997:2433
Bus 001 Device 006: ID 07ca:3835 AVerMedia Technologies, Inc. AVerTV Volar Green HD (A835B)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
For sure yes !! I did the server config from the IP:9981 as expected I think. I found all the channel that I expected to find (on the server)
And last time I test it I couldn’t activate the TV on Kodi without having very high temperature alert on my pi3.
But … there is a but … today (during we were discussing) I did it and no temperature alert appears at all !! Strange.
But unfortunatly that still doesn’t work because when I try to see a channel TvHeadEnd tells me that there is “no free adapter” … do you see what they mean with this message ?
Fzinken … I still not sure with the procedure but it works !!! I’ve to restart the tvheadend service actually … and now channel are available from the front … so sorry for the inconvinience
