kvdb
31 July 2018 07:05
1
on my RPi2 that has been running for months, I cannot access my external HDD anymore. Apparently, udisks and udisks-glue fail to start at boot:
osmc@osmc:~$ sudo systemctl status udisks.service
udisks.service - Disk Manager (legacy version)
Loaded: loaded (/lib/systemd/system/udisks.service; static; vendor preset: enabled)
Active: failed (Result: signal) since Tue 2018-07-31 08:55:06 CEST; 8min ago
Docs: man:udisks(7)
Process: 530 ExecStart=/usr/lib/udisks/udisks-daemon --no-debug (code=killed, signal=SEGV)
Main PID: 530 (code=killed, signal=SEGV)
Jul 31 08:55:06 osmc systemd[1]: Starting Disk Manager (legacy version)…
Jul 31 08:55:06 osmc systemd[1]: udisks.service: Main process exited, code=killed, status=11/SEGV
Jul 31 08:55:06 osmc systemd[1]: Failed to start Disk Manager (legacy version).
Jul 31 08:55:06 osmc systemd[1]: udisks.service: Unit entered failed state.
Jul 31 08:55:06 osmc systemd[1]: udisks.service: Failed with result ‘signal’.
osmc@osmc:~$ sudo systemctl status udisks-glue.service
udisks-glue.service - mount disks automatically with standby
Loaded: loaded (/lib/systemd/system/udisks-glue.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Tue 2018-07-31 08:54:42 CEST; 8min ago
Process: 250 ExecStart=/usr/bin/udisks-glue --foreground (code=killed, signal=SEGV)
Process: 193 ExecStartPre=/bin/bash -c sudo rmdir /media/*/ 2>/dev/null; time udevadm settle; exit 0 (code=exited, status=0/SUCCESS)
Main PID: 250 (code=killed, signal=SEGV)
Jul 31 08:54:41 osmc systemd[1]: Starting mount disks automatically with standby…
Jul 31 08:54:41 osmc bash[193]: /bin/bash: /dev/null: Permission denied
Jul 31 08:54:42 osmc systemd[1]: Started mount disks automatically with standby.
Jul 31 08:54:42 osmc systemd[1]: udisks-glue.service: Main process exited, code=killed, status=11/SEGV
Jul 31 08:54:42 osmc systemd[1]: udisks-glue.service: Unit entered failed state.
Jul 31 08:54:42 osmc systemd[1]: udisks-glue.service: Failed with result ‘signal’.
This seems like a duplicate of this issue: New install - disk manager (udisks, udisks-glue) fails to start . However, this was resolved by an update from last year, while my system runs the latest stable update.
We need full logs not snippets to diagnose this issue:
also what does journalctl report?
Thanks tom.
kvdb
31 July 2018 09:17
3
thanks a lot for the reply. Full logs are available at:
http://paste.osmc.tv/pipametoju
The output of journalctl:
osmc@osmc:~$ journalctl -u udisks.service
– Logs begin at Thu 2016-11-03 18:16:42 CET, end at Tue 2018-07-31 11:07:55 CEST. –
osmc@osmc:~$ journalctl -u udisks-glue.service
Thanks!
Koen
Looks like you messed up your repository line
deb http://apt.osmc.tv stretch main universe
kvdb
31 July 2018 09:52
5
I’m not sure what you mean by that. Even then, when I replace the sources.list by the clean version from here: Osmc update doesn't works - solved! - #9 by ActionA , the system seems up to date:
osmc@osmc:~$ cat /etc/apt/sources.list
deb Index of /debian stretch main contrib non-free
deb Index of /debian stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
osmc@osmc:~$ sudo apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 Index of /debian stretch InRelease
Hit:3 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:4 Index of /osmc/osmc/apt stretch InRelease
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
Koen
Well I meant that you have changed the repository line which might have created issues.
But as you seems upto date that seemed not causing any issue.
Only other thing I spotted in the logs is Process '/lib/udev/hdparm' failed with exit code 5. after your external disk is recognized
kvdb
31 July 2018 10:12
7
Ok, that might be the issue. Any idea on how to resolve this or process detailed logs on this process?
Not really but have you tried with another drive/stick?
kvdb
31 July 2018 11:14
9
Yes, both ways actually: the external HDD does work on my Ubuntu laptop, other USB sticks are also not recognized by OSMC.
Udisks fails at boot even when no storage device is attached.
Suggest a clean install on a second SD card. If that works than can try to reinstall certain libraries and packages
