Since the last update (2017.12-1, kernel 4.9.29-13-osmc) I’ve a strange issue. My Pi3 is unable to boot normally and falls into failsafe boot , but only if my USB Samsung Flash Drive FIT (128Go vfat) is plugged?
If I unplug this USB key before booting, everything is OK and I can plug it after kodi is started, kodi reconize it. It’s happen only with this USB key model, not with other (with smaller size) ?
When this Samsung Flash Drive FIT USB key is plugged at boot , systemd-udev-trigger.service fails. The journactl -xe command return the following log
janv. 11 22:16:34 osmc kernel: Hardware name: BCM2835
janv. 11 22:16:34 osmc kernel: task: ae22d880 task.stack: ab0d4000
janv. 11 22:16:34 osmc kernel: PC is at seq_read+0x13c/0x730
janv. 11 22:16:34 osmc kernel: LR is at 0xa0000013
janv. 11 22:16:34 osmc kernel: pc : [<80325e68>] lr : [<a0000013>] psr: 60000013
sp : ab0d5e48 ip : 00000000 fp : ab0d5eb4
janv. 11 22:16:34 osmc kernel: r10: 00000000 r9 : ab0d5f78 r8 : ae14ba80
janv. 11 22:16:34 osmc kernel: r7 : ab0d5e78 r6 : 803939e8 r5 : 00000000 r4 : abc97880
janv. 11 22:16:34 osmc kernel: r3 : 00000000 r2 : 00000000 r1 : ab0d5e78 r0 : abc97880
janv. 11 22:16:34 osmc kernel: Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
janv. 11 22:16:34 osmc kernel: Control: 10c5383d Table: 2ded006a DAC: 00000055
janv. 11 22:16:34 osmc kernel: Process udevadm (pid: 1757, stack limit = 0xab0d4210)
janv. 11 22:16:34 osmc kernel: Stack: (0xab0d5e48 to 0xab0d6000)
janv. 11 22:16:34 osmc kernel: 5e40: 0000000d abebb034 00000000 ab0d5ea8 ab0d5f78 abc978b0
janv. 11 22:16:34 osmc kernel: 5e60: 5580bf20 00001000 aded1560 abebb034 00000000 00000000 00000000 00000000
janv. 11 22:16:34 osmc kernel: 5e80: ae22d880 00000817 5580df2c abc97200 00001000 803939e8 5580bf20 ab0d5f78
janv. 11 22:16:34 osmc kernel: 5ea0: ab0d5f78 00000000 ab0d5ef4 ab0d5eb8 80393b1c 80325d38 000081a4 00000000
janv. 11 22:16:34 osmc kernel: 5ec0: 00000000 5580bf20 adceda78 ae14ba80 00001000 803939e8 5580bf20 00000000
janv. 11 22:16:34 osmc kernel: 5ee0: ab0d5f78 00000000 ab0d5f64 ab0d5ef8 802eae74 803939f4 80101240 808dbb18
janv. 11 22:16:34 osmc kernel: 5f00: 00000001 1c03a17f 00000c56 00000000 8038f91c ae14ba80 ae14ba80 00000000
janv. 11 22:16:34 osmc kernel: 5f20: ab0d5fa4 ab0d5f30 802f5d1c 802f4e60 00000c56 00000000 0000000f ab0d81a4
janv. 11 22:16:34 osmc kernel: 5f40: ae14ba80 00001000 ae14ba80 5580bf20 00000000 00000000 ab0d5fa4 ab0d5f68
janv. 11 22:16:34 osmc kernel: 5f60: 802ed664 802eae34 00000001 1c03a17f 5580bdb8 76e6fbec 00000000 00000000
janv. 11 22:16:34 osmc kernel: 5f80: 5580bdb8 76e6fbec 00001000 00000003 8010c748 ab0d4000 00000000 ab0d5fa8
janv. 11 22:16:34 osmc kernel: 5fa0: 8010c580 802ed5ac 5580bdb8 76e6fbec 00000005 5580bf20 00001000 00000000
janv. 11 22:16:34 osmc kernel: 5fc0: 5580bdb8 76e6fbec 00001000 00000003 00001000 76e6f7a8 5580bf20 7e9735c8
janv. 11 22:16:34 osmc kernel: 5fe0: 00000000 7e973454 76dd435f 76e10ac6 00000030 00000005 00000000 00000000
janv. 11 22:16:34 osmc kernel: [<80325e68>] (seq_read) from [<80393b1c>] (kernfs_fop_read+0x134/0x1b0)
janv. 11 22:16:34 osmc kernel: [<80393b1c>] (kernfs_fop_read) from [<802eae74>] (vfs_read.part.1+0x4c/0x1f4)
janv. 11 22:16:34 osmc kernel: [<802eae74>] (vfs_read.part.1) from [<802ed664>] (SyS_read+0xc4/0x1bc)
janv. 11 22:16:34 osmc kernel: [<802ed664>] (SyS_read) from [<8010c580>] (ret_fast_syscall+0x0/0x1c)
janv. 11 22:16:34 osmc kernel: Code: e594c048 e1a00004 e16721f0 e1a01007 (e59c3000)
janv. 11 22:16:34 osmc kernel: ---[ end trace ff48752911ec242e ]---
janv. 11 22:16:34 osmc systemd[1]: systemd-udev-trigger.service: Main process exited, code=killed, status=11/SEGV
janv. 11 22:16:34 osmc systemd[1]: Failed to start udev Coldplug all Devices.
-- Subject: L'unité (unit) systemd-udev-trigger.service a échoué
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- L'unité (unit) systemd-udev-trigger.service a échoué, avec le résultat failed.
janv. 11 22:16:34 osmc systemd[1]: systemd-udev-trigger.service: Unit entered failed state.
janv. 11 22:16:34 osmc systemd[1]: systemd-udev-trigger.service: Failed with result 'signal'.
If I boot on the previous kernel (dpkg-reconfigure rbp2-image-4.9.29-10-osmc) the problem persist ?
I’d not this issue with the previous OSMC release…
Remark: When I plug this USB key after boot, the kernel errors appears in the dmesg command but every thing works…
Thank for your help.
/boot/cmdline.txt =
root=/dev/mmcblk0p2 rootfstype=ext4 rootwait dwc_otg.fiq_fix_enable=1 dwc_otg.lpm_enable=0 quiet osmcdev=rbp2
/boot/config.txt
dtoverlay=hifiberry-digi-overlay
dtparam=audio=off
gpu_mem_1024=256
over_voltage=0
over_voltage_sdram=0
force_turbo=0
disable_splash=1
initial_turbo=0
start_x=1
sdtv_aspect=1
disable_overscan=1
hdmi_force_hotplug=1
hdmi_edid_file=1
arm_freq=1000
hdmi_ignore_cec_init=1
gpu_mem_256=112
gpu_mem_512=144
dtoverlay=lirc-rpi
dtparam=gpio_in_pin=13
dtparam=gpio_out_pin=17
