Hi there! I am having some issues building/installing Tvheadend to OSMC using this great tutorial: [Obsolete] Instructions for Viewing Live TV
I was able to fully run through that tutorial under Kodi 16 (and using Tvheadend when I updated it to Kodi 17 went fine), but now when I run it on a clean OSMC install, I get a fatal error. For the record, the (outdated) version included in the App Store never worked for me with my PCTV triplestick 292e.
My device is a Raspberry Pi 3, I am using the latest OSMC build and it is clean, apart from an installation of retrosmc.
After installing “gettext” so ./configure is able to run, and running through all the steps, the “make” command is causing issues. Please find the fatal error below:
Scanning dependencies of target common
make[4]: Leaving directory '/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/build/linux'
make[4]: Entering directory '/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/build/linux'
[ 1%] Building CXX object common/CMakeFiles/common.dir/arm/asm-primitives.cpp.o
*** Error in `/usr/bin/c++': double free or corruption (top): 0x01e521a8 ***
Aborted
common/CMakeFiles/common.dir/build.make:54: recipe for target 'common/CMakeFiles/common.dir/arm/asm-primitives.cpp.o' failed
make[4]: *** [common/CMakeFiles/common.dir/arm/asm-primitives.cpp.o] Error 134
CMakeFiles/Makefile2:258: recipe for target 'common/CMakeFiles/common.dir/all' failed
make[3]: *** [common/CMakeFiles/common.dir/all] Error 2
make[3]: Leaving directory '/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/build/linux'
Makefile:117: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/build/linux'
Makefile.ffmpeg:238: recipe for target '/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/.tvh_build' failed
make[1]: *** [/usr/src/tvheadend/build.linux/ffmpeg/x265_2.1/.tvh_build] Error 2
make[1]: Leaving directory '/usr/src/tvheadend'
Makefile:756: recipe for target '/usr/src/tvheadend/build.linux/ffmpeg/build/ffmpeg/lib/libavcodec.a' failed
make: *** [/usr/src/tvheadend/build.linux/ffmpeg/build/ffmpeg/lib/libavcodec.a] Error 2
I am quite the noob, so I do not know what to do now :(. I would appreciate it if you could help!
