On the first one my resolution is 1920*1080P(2D) and i have many choice in the resolution combo list
on the second one i have only two options: (720480P (2D) and 1280720p (2D) . 1280*-720 can’t play 3D Blueray …
Do you know wy i haven’t the complete list of resolution in the combo ??
(I tried back first vero to second without sucess… This append since i tryed a other TV on the second one. I put back the previous TV (3D one) but no change : my resolution have only to basic choice…
You clearly have a broken EDID reported. Suggest to check the cable and possible clean the contacts.
Or as mentioned maybe try the Vero on your other TV to see how it react there.
Ok many thanks, i’ll try tomorow and i’ll tell you: try on other TV first and clean the cable in second.
Just to know is there a way to setup the list or it’s a hardware checking without any software intervention ?
It’s work !!! many thanks : i can change the resolution now !!! Much thanks !!!
But 3D isn’t working … And i don’t know why: On a other vero4K i have exactly the same parameters for 3D and screen (1920x1080P (2D), 3D reading is based on based on hardware) and with the same blueray 3D file it’s work…
Is written on tv (instead of witching in 3D) :
“Mode 3D stereoscopic . monoscopic / 2D”
OK, we need to be a bit more sophisticated. Please plug your ‘good’ Vero into the TV you want to use with the ‘bad’ Vero and post logs:
reproduce the issue
Thanks Grahamh but i’m not sure to understand the value added of this. I wouldn’t break the good one wich is in the main lounge…
The ‘bad’ one was working well in kodi 19.1 with this cable and TV (untill i try to plug a HDMI to VGA with PC monitor. Now i put back the right cable and TV…).
After that the ‘bad’ one was blocked to low resolution.
Now the resolution is great with your good advice and JohanBakker one. But the 3D Blueray isn’t working. For information, few days ago, the “good” one update to 19.3 Kodi version (19.1 before) and the Blueray 3D had the same issues (not switching TV in 3D, written “Mode 3D stereo-monospcopic 2D”)… I try some random manipulation (x*y resolution in 2D, 3d, …) and it come to work. I don’t really know how.
Note the “bad” one is also now in kodi 19.3.
I try to backup the good to the bad without sucess.
