I would like to use bluetooth streaming from my RPi3 to my Creative Jam headset. Internal integrated wifi/bluetooth chipset on RPi3 is unstable on streaming, in fact no mather i do it is randomly drop connection without a reason during streaming and there is no other way to connect headset again without restarting osmc… So i bought USB dongle Mantistek WA150 which has wifi/BT 4.0 inside with chipset rtl8723bu. This chipset has no native support on osmc so i tried to compile it. The main problem is that i did exactly the same steps for preparing (compilation prerequisites) like on this post:
(ofcourse i changed everything what it need to be changed for this scenario)
with this git source and build steps for this specific realtek chipset:
but it endup with this result:
rtl8723bu$ make
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -C /lib/modules/4.4.27-7-osmc/build M=/home/osmc/rtl8723bu modules
make[1]: Entering directory ‘/lib/modules/4.4.27-7-osmc/build’
CC [M] /home/osmc/rtl8723bu/core/rtw_cmd.o
CC [M] /home/osmc/rtl8723bu/core/rtw_security.o
CC [M] /home/osmc/rtl8723bu/core/rtw_debug.o
CC [M] /home/osmc/rtl8723bu/core/rtw_io.o
CC [M] /home/osmc/rtl8723bu/core/rtw_ioctl_query.o
CC [M] /home/osmc/rtl8723bu/core/rtw_ioctl_set.o
CC [M] /home/osmc/rtl8723bu/core/rtw_ieee80211.o
CC [M] /home/osmc/rtl8723bu/core/rtw_mlme.o
CC [M] /home/osmc/rtl8723bu/core/rtw_mlme_ext.o
CC [M] /home/osmc/rtl8723bu/core/rtw_wlan_util.o
CC [M] /home/osmc/rtl8723bu/core/rtw_vht.o
CC [M] /home/osmc/rtl8723bu/core/rtw_pwrctrl.o
CC [M] /home/osmc/rtl8723bu/core/rtw_rf.o
CC [M] /home/osmc/rtl8723bu/core/rtw_recv.o
CC [M] /home/osmc/rtl8723bu/core/rtw_sta_mgt.o
CC [M] /home/osmc/rtl8723bu/core/rtw_ap.o
CC [M] /home/osmc/rtl8723bu/core/rtw_xmit.o
CC [M] /home/osmc/rtl8723bu/core/rtw_p2p.o
CC [M] /home/osmc/rtl8723bu/core/rtw_tdls.o
CC [M] /home/osmc/rtl8723bu/core/rtw_br_ext.o
In file included from include/linux/filter.h:16:0,
from include/net/sock.h:62,
from include/net/inet_sock.h:27,
from include/net/ip.h:30,
from /home/osmc/rtl8723bu/core/rtw_br_ext.c:24:
include/net/sch_generic.h: In function ‘skb_at_tc_ingress’:
include/net/sch_generic.h:414:2: error: implicit declaration of function ‘G_TC_AT’ [-Werror=implicit-function-declaration]
return G_TC_AT(skb->tc_verd) & AT_INGRESS;
include/net/sch_generic.h:414:33: error: ‘AT_INGRESS’ undeclared (first use in this function)
include/net/sch_generic.h:414:33: note: each undeclared identifier is reported only once for each function it appears in
cc1: some warnings being treated as errors
scripts/Makefile.build:258: recipe for target ‘/home/osmc/rtl8723bu/core/rtw_br_ext.o’ failed
make[2]: *** [/home/osmc/rtl8723bu/core/rtw_br_ext.o] Error 1
Makefile:1400: recipe for target ‘module/home/osmc/rtl8723bu’ failed
make[1]: *** [module/home/osmc/rtl8723bu] Error 2
make[1]: Leaving directory ‘/lib/modules/4.4.27-7-osmc/build’
Makefile:335: recipe for target ‘modules’ failed
make: *** [modules] Error 2
osmc@rpi3:~/rtl8723bu$
I tried to copy headers and kernel sources to /lib/… and also to /usr/src/… folders but it did not helped. Everytime i run make command it endup with the same result.
I tried to search on internet and found simillar problems with this same results when compiling on osmc 4.4.x-x kernel but no solution.
Than i tried to compile it the same way on my debian x64 system and it was compiled successfully and device is working.
Is there something i forgot to do (steps) or something else to build it successfully?
Can someone help?
Thank You for help.
