Unable to update, possibly A2DP issue?
Hi everyone,
I’ve been unable to update my OSMC (running on Pi3), ever since I installed retropi as a service. From reading around, I believe this is due to me installing bluetooth profiles? Can’t be sure however as my linux experience is rather limited. As requested, log is here:
https://paste.osmc.tv/yaguwocuqu
Any help resolving this issue is much appreciated, as I know i’m at least 6 months behind on updates and am missing some essential security patches.
Thanks and look forward to receiving any help!
Ian
After a bit more reading around (specifically here:
and
Udisks.service fails after latest update - #25 by dillthedog )
it would appear the error is caused due to using the Jessie staging repo? here’s my sources.list output:
osmc@osmc:/etc/apt$ cat sources.list
deb http://ftp.debian.org/debian jessie main contrib non-free
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://apt.osmc.tv jessie main
deb http://archive.raspberrypi.org/debian/ jessie main staging
deb-src http://archive.raspberrypi.org/debian/ jessie main staging
am I on the right track?
Well first I would try to remove this two lines and run update and dist-upgrade.
But you might have more issues than just that
Thank you fzinken, could you point me to a way to delete these sources? All my searches point to deleting media sources!
Well I wonder how you managed to get them in :slight_smile:
sudo nano /etc/apt/sources.list
A little knowledge is a very dangerous thing! :no_mouth:
Removed them, will try update again and report back, thanks for your help!
osmc@osmc:/etc/apt$ sudo apt-get update
Ign http://ftp.debian.org jessie InRelease
Hit http://security.debian.org jessie/updates InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://ftp.debian.org jessie Release.gpg
Hit http://apt.osmc.tv jessie InRelease
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Get:1 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [9,376 B]
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Get:2 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:3 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [3,688 B]
Get:4 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Get:5 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2,023 B]
Ign http://apt.osmc.tv jessie/main Translation-en_GB
Fetched 16.6 kB in 8s (1,988 B/s)
Reading package lists... Done
error is still present. further help appreciated!
Looks strange, reasons can be many (even a SD Card failure).
First upload new set of logs grab-logs -A
Second try
sudo apt-get clean
sudo apt-get update
New logs:
after reboot
https://paste.osmc.tv/onagivaqij
after running
apt-get clean
apt-get update
apt-get dist-upgrade
https://paste.osmc.tv/mixalayoso
Did the “update” still gave an error?
yes still get the error.
looking through the logs and a few forum searches, issue could be related to
libasound2-data 1.0.28-1+rpi2
The following occurs in the logs
Unpacking rbp2-device-osmc (1.4.0) over (1.3.3) ...
dpkg: error processing archive /var/cache/apt/archives/rbp2-device-osmc_1.4.0_armhf.deb (--unpack):
 trying to overwrite '/usr/share/alsa/cards/JustBoomDigi.conf', which is also in package libasound2-data 1.0.28-1+rpi2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
and
Log started: 2017-06-20  13:07:38
Preparing to unpack .../rbp2-device-osmc_1.4.0_armhf.deb ...
Log ended: 2017-06-20  13:07:40
Log started: 2017-06-22  16:20:08
Log ended: 2017-06-22  16:20:16
according to this:
using apt-get remove libasound2-data 1.0.28-1+rpi2
will delete the conflicting package. should I also use --purge to remove the associated configs? or am i barking up the wrong tree?
No looks like a possible culprit. So go ahead with that
osmc@osmc:~$ sudo apt-get remove libasound2-data 1.0.28-1+rpi2
Building dependency tree
E: Unable to locate package 1.0.28-1+rpi2
E: Couldn't find any package by regex '1.0.28-1+rpi2'
 libsdl1.2-dev : Depends: libsdl1.2debian (= 1.2.15-12rpi) but it is not going to be installed
                 Depends: libasound2-dev but it is not going to be installed
 libsdl2-dev : Depends: libsdl2-2.0-0 (= 2.0.5+4rpi) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Much thanks for your help fzinken. as you can see it appears to have not worked… I’ll try a sudo apt-get dist-upgrade again now and see what happens…
I think you first need to remove all the dependencies around libasound
are there any ways to resolve exactly which packages are dependant?
I’ve tried :
osmc@osmc:~$ sudo apt-get --purge autoremove libasound2
osmc@osmc:~$ sudo apt-get remove libsdl1.2debian
osmc@osmc:~$ aptitude purge libsound2
-bash: aptitude: command not found
osmc@osmc:~$ sudo apt-get purge libasound2
osmc@osmc:~$
but as you can see no dice!
Try apt-cache rdepends --installed libasound2
But what concerns me is this
ran apt-get -f install to fix the broken dependancies, then update and dist-upgrade, has gotten further into the install than usual… will report back!
  osmc@osmc:~$ apt-cache rdepends --installed libasound2
    libasound2
    Reverse Depends:
        liboss4-salsa-asound2
    osmc@osmc:~$ sudo apt-get remove liboss4-salsa-asound2
    Package 'liboss4-salsa-asound2' is not installed, so not removed
    You might want to run 'apt-get -f install' to correct these:
     rbp2-device-osmc : Depends: rbp2-mediacenter-osmc but it is not going to be installed
    E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
    osmc@osmc:~$ apt-get -f install
    E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
    E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
    osmc@osmc:~$ sudo apt-get -f install
    Correcting dependencies... Done
    The following packages were automatically installed and are no longer required:
    osmc@osmc:~$ reboot
    Connection to 192.168.0.3 closed by remote host.
    Connection to 192.168.0.3 closed.
@fzinken, out of curiosity, why is this concerning?
Well it concerns me as you might have set a “hold” on a certain package.
But let’s see where you get with the new success
Sorry, hit my post limit yesterday, but, it appears to have worked :smile:
osmc@osmc:~$ grep Kodi .kodi/temp/kodi.log | head -3
14:04:38.238 T:1958514688  NOTICE: Starting Kodi (17.5). Platform: Linux ARM (Thumb) 32-bit
14:04:38.238 T:1958514688  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
14:04:38.238 T:1958514688  NOTICE: Kodi compiled Oct 29 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
osmc@osmc:~$
It has borked my retro pie installation however, so now to figure out how to get that running again.
@fzinken thank you for your help! very much appreciated, and now I have a little more knowledge, and so am both more and less dangerous. Schrodinger’s hacker if you will. :joy:
