Hallo!
The December Update got stuck on my Rpi3 at 96% installing python-dbus and now I dont know what to do. Should I reset it? Or wait?
Any clue?
Thanks Alex
Update: I did a hard reset. And the Pi booted up ok. The Version of OSMC is 2017.12-1 and the Kernel is: 4.9.29-10-osmc
How can I check if there are unmet dependencies?
I had to do
sudo dpkg --configure -a
after that
sudo apt-get dist-upgrade
just showed the things that now can be removed with
sudo apt autoremove
Cheers!
Alex
Now I am not sure if all the packages can be safely removed?
Here is the list of them:
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
armv7-libcrossguid-osmc bluez libapt-inst1.5 libbind9-90 libdns100 libgif4 libgnutls-deb0-28 libhogweed2 libicu52 libisc95 libisccc90 libisccfg90 libjasper1
liblwres90 libmicrohttpd10 libmysqlclient18 libnettle4 libntdb1 libplist2 libpng12-0 libpsl0 libssl1.0.0 libwebp5 libwebpdemux1 libwebpmux1 libxtables10
python-dbus-dev
Can anyone give a hint if any of these could be necessary at all?
Thanks!
Alex
The current kernel on a Pi3 should be 4.9.29-13. That kernel version is from the previous version of OSMC.
Probably best to run grab-logs -A and post the URL.
I will run logs tomorrow. But shouldn’t that kernel show up in
Thanks!
Alex
Clearly something isn’t right. You should be on kernel 4.9.29-13 after a dist-upgrade.
Logs should show what has gone wrong with the upgrade
Hallo and thanks for your help so far!
Here are the logs:
https://paste.osmc.tv/zuzerivovu
I hope it will get something clear!
Cheers Alex
Try and post the output of a manual dist-upgrade.
Thats nothing to do except autoremove those packages…
Now I did the autoremove:
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen… Fertig
Paketaktualisierung (Upgrade) wird berechnet… Fertig
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Thanks for your help!
As I said the upgrade stopped at 96%. I waited very long about 15 minutes but the RPi was getting hot. So I did a hard reset and then did:
Then it went on and completed the changes. All seems well except that dillthedog said it should be kernel 4.9.29-13 instead of 4.9.29-10-osmc.
I am asking myself if perhaps the kernel integration did not work, so the kernel could be present but not active?
Is there something like grub on the device I can refresh?
Alex
The kernel 4.9.29-13 package has been installed:
ii rbp2-image-4.9.29-10-osmc 10 armhf Linux kernel binary image for version 4.9.29-10-osmc
ii rbp2-image-4.9.29-13-osmc 13 armhf Linux kernel binary image for version 4.9.29-13-osmc
but it looks like the full kernel installation process did not work. For example, there’s no mention in the log of any /etc/kernel/postinst.d scripts having run (or why not).
Perhaps @sam_nazarko can advise further.
Well, that sounds like a solution. Can I run the kernel install scripts manually?
Just run:
sudo apt-get install --reinstall rbp2-kernel-osmc
sudo apt-get install --reinstall rbp2-image-4.9.29-13-osmc
Glad this has worked for you. Let’s keep an eye on things and make sure they update properly with future updates.
Thanks for that, I appreciate!
I hope the SD card is not dying! No idea why it got stuck at the end of updating…
But I can save the configs on my NAS so a new install is not that much work. I am very happy with OSMC!
Alex
