I forced the update on my Raspberry Pi3 by using the command line via SSH :
sudo systemctl start manual-update
But then after 5 minutes of downloading new packages, I got the message “An error occurred while installing… Unknown package”
What should I do ?
EDIT : I should add that I had to force the update via command line because trying to update via “My OSMC” was unsuccesful : the update apparently browse debian repositories and then does… nothing… even though there is an update pending from last august.
Yep seems everything is ok now
I’m now booting into Kodi v19.1 successfully.
Thanks so much.
No idea why the process was so convoluted for me.
I had been disabling Automatic updates for 1 year (since November 2020), only occasionally checking manual updates from time to time. Is that why ?
EDIT : oh by the way, the new update runs incredibly smooth !
Such an improvement in performance and fluidity
