I have used OSMC for several years and the last time I updated the system was about a year ago.
So now I thought I should let it run an update again.
After the update was finished I have lost my media drive!
It is a USB connected 1TB NTFS formatted hard drive containing all of the media I use.
Previously it was visible on the network (samba shared) and I could copy in the videos I want to view, but now the drive is not visible from my Windows 7 PC or my Linux server anymore.
And within KODI I used to be able to browse to Files and select the media drive and then navigate to the files to view.
This is all gone now, no media drive visible and the NAS drive I had attached to KODI as another media drive is not visible in the KODI interface either…
So all in all I am stuck with a broken system it looks like.
What can I do to:
Get back my shared media drive on line with network access
Make the media drive visible from within KODI when navigating Videos/Files
I think the problem is solved.
I had to go in using PuTTY to a command prompt and issue “sudo reboot”.
After the restart my media drive was recognized again and shared as before on the network.
So the bottom line is that following an update one has to run a hard restart.
And I talked too early…
I need the publication of the video drive to my Smart TV, and it did not list anytrhing even when the USB drive was available inside KODI itself.
Since rpi2-osmc (the name of the OSMC box) was not listed on the TV I looked at the services and found that Upnp was not enabled. So I enabled the service and set it to share the libraries. I also rebooted the RPi.
Now what happened is:
On the TV rpi2-osmc appeared and could be selected and inside the video library section I found the NAS drive OSMC is connected to via the network (samba share). And it worked to play from that. But the internal USB drive was not shown in the list.
On KODI itself the USB media drive has also disappeared!
Finally when I check the network from my Win7 and Linux boxes it appears that the shared drive on the OSMC box has disappeared!
I have now tried to revert the changes I did (disabling UPnP again) and rebooted the box (I even pulled the power line on it).
But no luck! It seems like now the USB drive is permanently missing!
So now it is no longer possible to view the videos on the media drive even from KODI…
What can I do now?
I have checked that the USB drive itself is not broken. It works fine when moved to my Win7 laptop.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
I have tried to get things working on the OSMC box all day and I could manually mount the USB drive and then things styarted work but when I reboot I get back to the situation where the USB drive is not working.
Here is the URL to the logs after a restart: https://paste.osmc.tv/jujihofidi
I guess that I need something like this in /etc/fstab:
Generally it would not be absolutely necessary to use fstab entry as OSMC normally does an automount.
But looking at your logs seems that something is not working there. can you post output: fdisk -l /dev/sda | paste-log blkid /dev/sda1 | paste-log ntfslabel /dev/sda1 | paste-log
osmc@rpi2-osmc:~$ fdisk -l /dev/sda | paste-log
https://paste.osmc.tv/sokusawuta
osmc@rpi2-osmc:~$ blkid /dev/sda1 | paste-log
https://paste.osmc.tv/ucupihokex
osmc@rpi2-osmc:~$ ntfslabel /dev/sda1 | paste-log
Access is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
You can use force option to avoid this check, but this is not recommended
and may lead to data corruption.
https://paste.osmc.tv/ubekenefiq
Note that I have manually entered a mount command in order to check out the UPnP functionality, and it does work on the LG TV.
sudo mount /dev/sda1 /mnt/mediadrive
However I cannot get the samba share working…
Nor does it mount on reboot (but I have not entered any active line into fstab yet, my proposal is in the log)
This could indicate either that it somehow at that moment was mounted or that there is an issue with the filesystem.
You would need to restart samba after manually mounting it.
But if you want to go down that path suggest to do it via fstab.
But still questionable why the partition is not automounted.
Then rebooted and now the media drive is functional and visible via UPnP on my TV.
However, while waiting for the boot I noticed that there were error messages concerning smb, so I have made another log and uploaded to https://paste.osmc.tv/sovometona
Here is the smb.conf file, except WORKGROUP is another name:
[global]
config file = /etc/samba/smb-local.conf
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
comment = OSMC Home Directory
[mediadrive]
browseable = yes
read only = no
valid users = osmc
path = /mnt/mediadrive
comment = Media root Directory
[automount template]
browseable = yes
-valid = no
valid users = osmc
path = %P
hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
include = /etc/samba/smb-shares.conf
Both smb-shares.conf and smb-local.conf are non-existent
If I manually issue:
systemctl restart smbd nmbd
then samba starts…
UPDATE:
I made the change that I renamed the smb-shares.conf and smb-local.conf in /etc/samba/ by adding .disabled at the end of their names. Contrary to what I believed the files contained commands.
Now samba starts as it should on reboot!
But I need to make a backup copy of smb.conf and fstab since OSMC updates seem to replace these files with stock versions.
Seems like it is working now.
Does this mean commenting out all content in smb.conf except the references to the two sub-files?
If not then there will be conflicting settings, which I think were the cause of the startup errors until I renamed the files.
So if I make smb.conf look like this (erasing everything else in the process):
[global]
And then I have everything except the share definitions in smb-local.conf and the shares in smb-shares.conf it will work as before with the exception that any system update will NOT touch samba config?
Well based on the instructions in smb.conf you should just have: sudo cp smb.conf smb-local.conf sudo nano smb-local.conf
And remove config file = /etc/samba/smb-local.conf from that file and do the other changes you want to do.
From the manual There is a chicken and egg problem here as this option is set in the config file! For this reason, if the name of the config file has changed when the parameters are loaded then it will reload them from the new config file.
Thanks for the explanation, now it all makes sense.
I have enabled smb-local.conf and put all I need into that file.
No use of smb-shares.conf anymore.
After a restart of samba:
the shares work as expected.
Now I will proceed to duplicating my OSMC media center on a RPi3B+ (the current is on RPi2B)
