This is a fresh install. PiB2 is the main unit sharing the library via UPnP. The PiB is in the bedroom.
Under Alpha 4 I had UPnP library sharing working fine and I am trying to do the same now with the RC but it won’t quite work.
The files show up, I can see the file and the associated data but when I select the file to pay it doesn’t start and throws a playback error that the file can’t play and to check the log.
Here is the log: it seems to be trying smb as well:
It’s set up the same as it was under Alpha 4 so I’m a little lost because it was working really well. I know UPNP isn’t the best but for the bedroom it’s all we need.
I did install Samba from the app store. Could something be clashing?
Turn on debugging, reproduce the issue and provide a new log.
Edit: If you use the log uploader in My OSMC you can choose to upload all logs which gives us a better idea of your setup.
But turn on debugging first.
Before we dig deeper, are you trying to share anything provided by an addon via UPNP?
If so, I am pretty certain that UPNP only works with local content even if it is scanned into library.
However, the smb error you get shows as a permission error in the debug log.
So that is without a doubt a simple permission issue that probably needs to get fixed on the server end.
The permission issue is the actual issue.
UPNP will share the it´s sources which in this case is shared via smb, so sort of a relay.
So you need to look at the permissions on the smb shares.
Niether, unless you share your local content via smb from and to the same Pi on the “main” setup?
The permission issue should be fixed wherever you share your content from via smb.
Let´s get everything correct;
where do you share your content from to your first Pi?
Edit:
You might have stumbled upon this issue: http://forum.kodi.tv/showthread.php?tid=167059&pid=1442884#pid1442884
You could try to copy passwords.xml, or set up your sources on the first Pi with user:passwd in the URL, and see if that resolves the issue, but I would still recommend jut setting up the original smb share as source instead.
I got it working - not sure if it’s related to the link you provided.
All I did was begin setting up sources via SMB rather than UPnP. I did not have to run a library scan. I then removed those two sources that I created (Movies & TV Shows) and attempted again to set up via UPnP and it worked straight away.
Might be a “bug” in the way UPnP is implemented or as there was no SMB source initially set up the UPnP relay had nowhere to look.
Under Alpha 4 I did the same thing - set up initially via SMB until realising I could share the library via UPnP. Back then I did not know what effect this would have. I would have had the same issue as I had today.
Glad it´s working now.
I bet that if you check your log now you will have the user:passwd in the URL that UPNP provides.
Either that or you have a proper passwords.xml with all info which didn´t exist before you added the smb share.
I have my main raspberry pi in my living room with a few HDs full of movies that works flawlessly
Another in a front room with no HDs. And another in a bedroom. No HDs connected. I am attempting to be able to share the content with the two pis without having to physically move the HD and restart.
Not asking to much right. I can see the drives once I enabled the upnp but. Can’t get anything to play. I’m going to reinstall the newest version of kodi and start all over to see if all my tinkering created some issues.
Any advice? Anything step by step I need to do? Must be possible from all I read but I’m sure having some block somewhere!
Thanks for any help. I’ll keep you informed of my progress!
