Hello everyone, I was just wondering if any of you can help me out, Ive done all the steps to make the patch stick, install everything, everything runs smoothly until I turn off the Apple TV for the day, next time I want to go and use it the osmc patch stick won’t run, I have to format and redo the paths tick all over again but it keeps happening everytime I do it.
Does anyone know about a solution for this? I will appreciate the help
I’m using a 8gb Kinsgston usb drive
You probably selected a hard disk installation. Hard disk installations are only now working properly. You can read more at OSMC on Apple TV. Better than ever. - OSMC.
I used the USB installation, do you think the brand and capacity of the usb drive matter, If so witch ones do you recommend to make it more stable?
Yes, some sticks don’t work correctly.
Minimum recommended size is 8GB. More details are in the FAQ linked below:
As for which stick to use, search the forums. Some people have posted what worked for them.
We discussed having a list, but based on past experience, it’s a bit problematic, because it’s a constantly shifting target.
