USB TV Tuner not working
I have updated my test unit to 2022-09-1 and then performed:
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
When plugging the 950Q dmesg still shows Unsupported Device, dmesg output is the same. Side note: after a bunch of plugging and testing, my dualHD tuner seems to have broken today (not working anymore on separate Windows PC, unrecognized USB device), so all future work/testing will be with the 950Q model tuner.
Hi @slow – this should now work again.
See Hauppauge 955Q tuner
