Any plans to offer support for USBTV007 Grabber?
Thank You
Thank You
I works out of the box … and I must say … in Alpha 4
See: Hyperion with Fushicai UTV007
Nothing really special done, just google and follow a few guides.
Hi Theetjuh, I tried to connect my grabber and not recognize both alpha 4 and RC
You tried other usb ports?
When I connect it, it makes an /dev/video0 and I see this with ‘dmesg’ thru ssh…
[ 2.538763] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.642271] usb 1-1.2: config 1 interface 0 altsetting 1 bulk endpoint 0x83 has invalid maxpacket 256
[ 2.645479] usb 1-1.2: New USB device found, idVendor=1b71, idProduct=3002
[ 2.645507] usb 1-1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 2.645524] usb 1-1.2: Product: usbtv007
[ 2.645541] usb 1-1.2: Manufacturer: fushicai
[ 2.645556] usb 1-1.2: SerialNumber: xxxxxxxxxxxxx
[ 3.409027] Linux video capture interface: v2.00
[ 3.452076] usbtv 1-1.2:1.0: Fushicai USBTV007 Audio-Video Grabber
[ 3.452336] usbcore: registered new interface driver usbtv
With ‘lsmod’ it shows everything loaded as well…
usbtv 11091 0
videobuf2_vmalloc 3009 1 usbtv
videobuf2_memops 1552 1 videobuf2_vmalloc
videobuf2_core 33578 1 usbtv
v4l2_common 5077 2 usbtv,videobuf2_core
videodev 122487 3 usbtv,v4l2_common,videobuf2_core
