After the recent update, when trying to view recorded TV or trying to view live TV, Kodi crashes to a black screen with some writing in the upper left (it’s gone to fast to read), then the “sad face” screen appears and the Vero reboots.
I don’t see much in the logs (but I may be looking in the wrong place: .kodi\temp). This is the only thing I think is relevant in the log but it doesn’t provide much info:
“ERROR: PVR - ConnectionStateChange - invalid handler data”
Anyone have any ideas or places to look for possible solutions?
The update that pops up on the screen asking if you want to update. Not sure if it’s Kodi or OSMC that is driving that update. Definitely not a MediaPortal update.
The issue you are currently experiencing with OSMC
Kodi crashes and reboots when trying to use MediaPortal add-on.
What you were doing when this issue occurred
Trying to view either live TV or PVR shows with MediaPortal add-on.
Whether you can replicate this issue on demand. If you can, then please provide some steps on how an OSMC developer can reproduce the same issue.
Yes, can be replicated on-demand.
The device you are currently running OSMC on
Vero 2
What peripherals are attached to the device?
Bluetooth mini keyboard
Has this issue been introduced by a new version of OSMC? When did the issue first appear and can you recall a time when it was not present?
I believe so. Seems to have appeared with the first update in February.
I disabled the Library Watchdog add-on and Kodi still crashes.
Even though the event log doesn’t explicitly state a crash occurred, I believe the crash happens after this event:
17:09:07.845 T:3769365248 ERROR: PVR - ConnectionStateChange - invalid handler data.
I’ll try to recreate the crash again and upload new logs.
