I am thinking of running a Vero as an alternative to an ultra-expensive Melco for stereo hifi. I hooked a Vero up to a USB DAC today and got some promising results. However, I’m not convinced I’m getting the purest of unprocessed PCM, since, for example, it’s possible for me to change the volume via Kodi, even though in theory I have a passthrough connection to the DAC.
Would it be possible to configure the audio in a way that absolutely no processing is done, apart from rendering the incoming file to PCM ?
Curious to know if anyone has used the Vero with a fairly high-end DAC and compared performance vs a Melco ?
Also, does the Vero support asynchronous USB in order to be slaved to the DAC’s clock?
I had forgotten about this thread. For an audio purist, options could include installing Volumio on a Pi, or RoPieee on a Pi to turn it into a Roon bridge, if you have a Roon Core on your network. I was sceptical about Roon but have been converted.
Thanks Sam. But my DAC is USB fed only and I want to connect it analogically to Amplifier (RCA) . And only for music. For movies I want to use HDMI connection to digital receiver… Do I need to switch “allow passthrough” back and forth and change AMLDM8I / DAC everytime?
…and , I forgot. One issue: Vero hangs each time I browse for subtitles. I either have to have it in same folder OR use download subs… If I browse it freezes…
Yes. Select DAC, Analog is clear. “passthrough not needed” is not (to me). Do I not need to allow passthrough in order to have my DAC decode instead of having Vero doing it?
Hi AC, I am trying to use Vero4k+ as transport to a cheap (but satisfactory) Topping D10 USB DAC. The DAC goes analog/stereo into a Technics SE-A900. I see I can select D10 Analog as Output device in Kodi, but I do not understand why I do not need to allow passthrough as Sam tells me. Iif don’t tick Alllow passthrough I cannot select a passthroud device!
Passthrough means an encoded audio stream, such as DTS or Dolby Digital is passed to an external decoder (normally an AVR).
It seems your DAC takes uncompressed PCM or DSD. Kodi/Vero does not support DSD passthrough but I think Kodi can convert DSD to PCM if DSD is what you’ve got. Your DAC will be converting PCM to analogue.
