Firs time try to to set transmission on vero 4k. Transsmision instaled through app store.
I ssh to my vero 4k :
used comand: sudo nano /home/osmc/.config/transmission-daemon/settings.json
( and tried to chang download directory to my NAS WD my cloud mirror. My NAS is connected throug FSTAB)
so I changed:
“download-dir”:“/mnt/siusti”,
“incomplete-dir”:“/mnt/siusti”,
everything else stayed as default then ctrl+X Yes and Yes
So it looks that I changed downlowd directory on may web browser on transmission I see:
rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
#/dev/vero-nand/root / ext4 defaults,noatime 0 0
192.168.1.5:/mnt/HD/HD_b2/Muzika /mnt/Muzika nfs x-systemd.automount,noauto 0 0
192.168.1.5:/mnt/USB/USB1_c2/CloudUSB1/musicvideo /mnt/musicvideo nfs x-systemd.automount,noauto 0 0
192.168.1.5:/mnt/USB/USB1_c2/CloudUSB1/siusti /mnt/siusti nfs x-systemd.automount,noauto 0 0
And if I verify my FSTAB
osmc@osmc:~ $ sudo mount -a
mount: /etc/fstab: parse error at line 1 -- ignored
It shows some eror but everything works perfect (like movies , skiping chapters)
But if I try to downlowd using transmission as discribed in the first post got message : read only file system
Thanks everybody for quick support.
I am engoing my vero 4k
Learning by doing
I checkd on my NAS (WD Mycloud mirror) all my shares is made for admin with password with read/ write.
I changed my share /mnt/siusti for public , so that now means that I can access it on any computer on my network without any password with read/right posibility.
But any way the same message on transsmision web interfase: read only file system
I tried and joakim_s advise that to run :
ln -s /mnt/siusti /home/osmc/Downloads
and then changed transsmision download directory to /home/osmc/Downloads/siusti
But then get such error :
So can not understand until the end where is a problem? Brr… Is FSTAB just for read?
systemd-1 on /mnt/siusti type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
192.168.1.5:/mnt/USB/USB1_c2/CloudUSB1/siusti on /mnt/siusti type nfs (rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.5,mountvers=3,mountport=50414,mountproto=udp,local_lock=none,addr=192.168.1.5)
