Glad that my explanation made sense to you
I only noticed then that the confusion mightâve come from the âit was working with Pi beforeâ corner. Please do test the settings and get back to us afterwards
Ok so tried them out as suggested:
Via ARC
Number of channels 2.0
Allow passthrough enables
AC3 enabled
DTS enabled
DTS-HD disabled
True HD disabled
Dolby tracks and TrueHD files passed through as Dolby (as expected) however DTS or DTS-MA was not passing through at all, I did a bit more googling and it looks like Samsung may removed support for DTS from their TVs at some point this year for some crazy reason so I decided to disable DTS capable receiver and sure enough a signal gets passed through to my AVR now from a DTS file, albeit a dolby signal if AC3 transcoding is enabled. So a bit weird, but it is some form of working now.
I tried the above settings via optical as well for good measure as this is obviously the better way of doing things, and they do work (both dolby and DTS this time!) but the same as before only if I unplug the HDMI cable from the AVR output to my TV, otherwise I get no sound at all.
I hope this makes sense
Thatâs⌠typically Samsung.
Do you have a link to this?
This makes absolute sense and, although it would be sad for you to suffer from such an indeed very strange decision by Samsung, Iâm glad the settings are working as expected for you
If you have any further question, feel free to askâŚ
Out of curiosity: Did you read-up on the wiki article and, if yes, how was the read? Having dug into audio things for a while already (and therefore possibly having lost the understanding of what others may want to get explained and how), Iâm wondering whether itâs helpful to those whoâd like to expand their knowledge and get their setup running (and it not simply being a long sermon that might be too complicated and too long for that purpose).
Thatâs unbelievably silly of them. My guess is they have some licensing issue they donât want to pony up for.
Iâm sorry we canât offer a solution for this; but AC3 transcoding will sound pretty close to the mark.
Thanks for letting us know â Iâm sure you wonât be the first to report this. I do wonder if you can downgrade your TV firmware and get this functionality back?
Yes thanks for all your help.
I did have a good read through them, I have to admit on first pass through they did seem quite lengthy and in depth, but now having had a bit of a play around myself it is a lot more understandable and clearer.
I donât think the content of the wiki thatâs a problem, but I do think the layout is a bit difficult on first read as there is a lot of terminology that a lot of people wouldnât necessarily have come across before that is then explained further down the article in the FAQ section.
But as I said the content itself is very informative and useful, once I got my head around it
Yes that was my first thought too about licensing, but for the price they charge for one of their premium line TVs, itâs a bitter pill to swallow if they couldnât cough up the extra to include DTS.
I did also think about looking into downgrading firmware but Iâm all honesty Iâm not sure the reward would be worth the risk of it all going wrong.
I do appreciate all your help and support, especially considering it turned out the issues had nothing to do with your device
Weâre in agreement then.
Itâs being improved and in my eyes doesnât meet the standard of OSMC any more. Iâll be asking for feedback in the forums as we develop new resources; so feel free to chime in.
Yes, thatâs quite annoying. Iâm not actually sure about the legality of selling something and removing its functionality unless they reserved the right to do so. They donât have to maintain the TV in terms of firmware updates; but they should give you the right to use a version where it worked.
No sweat.
Thank you for the feedback. Yes, layout is absolutely an issue!
Thank you @sam_nazarko, and thank you @Chillbo particularly for all your patience in helping us work through this.
I think this is also working for me now as well. Iâm using the same settings that @james.a.milner posted earlier, with DD+ also enabled, all via ARC. As a result, iâm getting:
DD 5.1 passed through
DD+ 5.1 passed through (I think. It may actually be transcoding to regular DD 5.1)
DTS 5.1 passed through
TrueHD transcoded to DD 5.1
DTS-HD MA transcoded to DTS 5.1
AAC 2.0 output as PCM 2.0
AAC 5.1 transcoded to DD 5.1
All output just fine. The only problem iâm still experiencing is that now John Oliver files are stuttering unwatchably (they were ok before transcoding was switched on), but that looks to be a quirk of a specific encoder because theyâre the only files iâve found with the problem.
I think part of the problem you had in getting this into my head was the fact that setting my speakers to 2.0 seems completely counter-intuitive. I realise now that this doesnât apply to passthrough, and is a means to enable transcoding, but that isnât super-obvious in the Kodi GUI. I also struggled with the fact that my AVR supports native TrueHD and DTS-HD MA, so why would I want to transcode them? It all felt completely backwards.
I did read through the Wiki articles you linked, and I think the repeated emphasis that S/PDIF only supports 2-channel LPCM is slightly misleading (especially when I was also setting my speakers to 2.0) because weâre trying to achieve 5.1 output.
Theres also a bit of âIf this, then that, except whenâ involved. For example, my situation matches the section titled âRecommended audio settings when using your AVR/soundbar/TVâs HDMI inputâ but iâve ended up using a combination of settings from that section and the following one to get the desired result. I know that is called out in the text, but it becomes a bit of a logic maze to follow.
I honestly donât know how you could write it up any better though. There are quite a few different technologies and use cases that you need to cover, and you do call out everything the user needs to know, so it should work.
In any case, thank you for your perseverance. I really appreciate it. I now have 4k HDR video and multi-channel surround sound. Its a fantastic result, and you guys are awesome with your support
Since you mentioned John Oliver. In my experience only the 720p version with The doosh tag has bad audio and only if HW acceleration is enabled. If you disable HW acceleration it will play fine. The 1080p version taged as Monkee plays fine even with HW acceleration enabled
Great that you could figure it out, @Arathen! The issue is indeed, every time that we have to get what the setup actually is, what the devices are capable of, what users want to achieve and which settings have to be choosen in order to get there. So, itâs often easier for users to understand things on their own with some guideline/explanation first - otherwise a lot of writing back and forth has to happen and confusion can arise. The wiki article is an attempt to make this easier, but itâs very difficult to cover everything in a very easy to understand and broken down fashion.
Unfortunately, I donât see a good way around those âIf this, then that, except whenâ you mention.
Maybe a click-through guide where you click âmy AVR can do thisâ, âmy TV can do thisâ, âI want to connect my OSMC in this wayâ, etc. with some recommended settings being output at the end might be good. But probably quite difficult to do. Weâd have to cover many, many scenarios and combinations. And users still have to know what their devices are capable of (e.g. the DTS limitation of @james.a.milnerâs TV)âŚ
Iâve noticed that it seems to be particularely confusing for users to get the 2.0 PCM part, yes. It might be confusing at first, but if youâre aware of the difference between PCM and passthrough formats as well as the capabilities of S/PDIF, itâll be much more obvious. Not sure though whether we can change the GUI in that regard to make this clearer. In the end, users will have to understand PCM and the limitations of S/PDIF and ARC IMHO ![]()
Weâre always here to help, but it would be good to have a wiki article that covers most for most users and then we can go on working on specific, individual settings after that read. Thatâs at least what we intended the article to be for. Help with improving it is always welcome!
John Oliver encodes have been known for some bad encoding, yes⌠Weâve seen quite some reports on the forum about this.
Just curious about where I can purchase these John Oliver shows. It sounds like youâre saying there are different encodes of it, so is that for different devices (TV, mobile phone etc) or are you buying the DVDs and ripping them yourself. Seems like if you were buying DVDs or recording the live show and encoding it, you would know what encoder youâre using.
Anyway, Iâm a fan of Oliver and if someone could let me know where to purchase these encodes that would be great.
Robert
Its on Amazon Video
Oh I see, didnât realize you were talking about streaming video. Odd that the different streams from Amazon would be using different encoding and be tagged with weird references like âMonkeyâ or âdooshâ. Could you elaborate on how you access these streams and identified the tags you mention. I would be interested in seeing if my system has the same issues.
Robert
If you legitimately buy your media I donât think you should have any issues. Doosh and Monkee are release groups or Individuals that buy the media, capture it, remove DRM and than release it to the public. I guess the Doosh guy or guys do something with the media that causes playback problems with vero if hw acceleration is enabled. I donât want to promote or discuss piracy here or get anyone in trouble.
You shouldnât need to transcode DTS MA 5.1 as it has the core track built in and should just send that if the decoder (?) doesnât recognise the lossless part. I used to get this on a BR player. Unfortunately with TrueHD it doesnât have a core track as far as I remember so if I rip I always rip the standard DD track alongside, just in case a device I want to use doesnât support TrueHD
@Paul_Solecki, itâs not trancoded anyway (thereâs only trancoding available to AC3)⌠Itâs just the wrong terminology being used here. It being played as DTS 5.1 means that the core track is passed on to the receiving device. All fine here ![]()
Yes and no. The UHD BD and BD standard defines that an additional lossy Dolby Digital track must be present which is bound to the lossless track (itâs additional, not seperate). But container formats like MKV donât know that structure, only the UHD BD/BD formats knows this. So, if youâre ripping to MKV, yes, you have to add the lossy track from a disc seperately to the rip.
True-HD tracks have no âcore DD 5.1â tracks embedded within the stream like DTS-HD MA does. The specification states that if there is a True-HD track then it must also carry a separate DD 5.1 track. It however is not embedded within the True-HD track. It is based on the Meridian Lossless Packing (MLP) codec.
