After a week without use, I immediately wanted to enjoy the Vero 4K. I turned on the screen, updated an extension, and waited a few minutes to answer a phone call. Then I saw the Vero stop (on the screen, Linux messages) and nothing more: red cross lit on the front.
For your information, I’m looking at the processor temperature which is 111°c without doing anything : it’s a lot, isn’t it? Knowing that the Véro is not on another device: it is alone on a TV cabinet shelf, with nothing in a 20cm radius.
Thank you for your help… it’s starting to be unpleasant.
I installed Vero 4K from blank and add things I Ould like to have, things I had in my previous Kodi system, like a screensaver or a skin, tout it crashes (always red light)
Now, without screensaver except “Dim” and with the Aura skin (not the most greedy it seems to me), the temperature is 73°c. No movie played, nothing, Judy idle, from the last 24 hours. Is 73°c a correct temperature ? I repeat there is nothing under or on the Vero.
I would suggest testing on a stock installation first.
You say the device crashed when scanning the library. Did it repeatedly crash, or just crash once?
If it only crashed once, I wouldn’t be particularly concerned. It could be a corrupted file that caused this.
As already said, I don’t want a perfectly working Vero I can’t use to do what I need it to do. If I can’t read 3D MVC file, I don’t need a Vero 4K +. I already forgot the skin I used from several years, forgot the screensaver… finally, if I have a very nice Vero 4K+ I don’t like to use, what for ?
“It could be a corrupted file that caused this” : it looks very strange for me that a corrupted file crashed an hardware system (red light on). An error, something we could see in the log, yes, but nothing except a red light on ? for a corrupted scanned file ?
…I just run a new library scan : the processor temperature is 107°Celsius now. I presume It will probably crashed with a good Red Cross light on.
…can’t we imagine there is an hardware problem on the Vero I received ? The absence of heat sink or something like that ?
I am asking you to test with 3.14 because this is the stable release. By using an experimental build you are introducing more variables.
Before we would check for a hardware problem, we would surely rule out a software problem first.
If you believe it’s a hardware problem, then you can open a warranty case at support@osmc.tv, but I don’t think the hardware is faulty from what you have described so far.
Unfortunately you haven’t uploaded debug logs – so it’s hard to look in to the issue further.
I made what you told me to do to be able to work as promised.
I’ll do that, but want one again test your “clean installation”.
it’s done before “stocking installation” : you probably missed my message 6 before yours.
So, I asked you how to do a “stock installation” by telling me what to write in “sources.list” to do the clean installation as you asked me : could you help me ?
