Hi @sam_nazarko
The USB/Ethernet dongle I use is the Anker USB 3.0 Portable Gigabit Ethernet Adapter, which I believe uses the Realtek RTL8513 chipset. I use it because without some of my 4K movies stutter, for example 2001 A Space Odyssey is unwatchable without it.
I bought the dongle in Dec 2018 and have been using it with my Vero 4K since then without issue, however, the moment I installed the August Linux 4.9 update I experienced issues with it.
As I have posted elsewhere on these forum, when I updated to the August release my Vero 4K was not updating the time and date correctly, it was surmised by others that from my logs that the NTP service was failing to start… this it seems was down to the USB/Ethernet dongle not being initialised correctly, I also get a failure to connect to an external metadata database warning message…
Removing the dongle and inserting the Ethernet directly fixed the time and date issue.
I have done I quick search for Realtek RTL8513 chipset online, and while it’s not clear, it does seem that the Linux 4.9 kernel which I believe was part of the big August update is no longer supports the Realtek RTL8513 chipset natively.
However, if the issue is that the dongle is drawing too much power, than I must question the specification of the USB ports on the Vero 4K, as I thought they should be supply 0.5 amp each, which would be more than enough to drive the dongle.
IF however, the Vero 4k update is now drawing more power, and therefore affecting the USB ports, then I need to know, as the update has rendered by Vero 4K obsolete. It also raises the question of how suitable the Power Supply that comes with Vero 4K is, if the USB ports can now no longer drive a simple dongle.
If it is a power issue, fine… I will get a powered USB hub, but I need to know, I don’t want to spend more money only to find that it is in fact a driver issue.
