Hi!
After some months turned off I connected my Vero 4k today, but it does not boot properly. The red light on the front is on and that’s it. Even with telnet I get no access.
Is there anything else I can try?
Many thanks in advance!
G
Try another PSU. If you don’t have a 5V,2A PSU with a barrel connector, another way is to use a (minimum 1A) USB PSU with a USB A-A cable.
Thanks a lot, that worked. I took the PSU from the old Vero 4k.
Now I face the next problem. My OSMC Version is fom November 2020 and it doesn’t update. So I did this:
Go to My OSMC → Updates → Manual Controls → Apply Hotfix. Enter ucawobahij and proceed. You can now update your device via My OSMC or the command line
but still get the connectivity issue message. Is my OSMC too old for that hotfix?
KR
G
What exactly is the message?
“Connectivity issue while checking for update”
I’m just guessing but I think you have to apply the hotfix mentioned in this post
OP has attempted that already but I think Connectivity issue just means he’s not connected to the internet.
No, Vero 4k+ is definitely connected to the internet!!
When I’m doing the update via command-line I get this.
Blockquote
login as: osmc
osmc@192.168.1.73’s password:
Linux Vero4k 3.14.29-160-osmc #1 SMP Sun Sep 13 13:55:21 UTC 2020 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Jan 7 15:59:09 2023 from 192.168.1.2
osmc@Vero4k:~$ sudo apt-get update
Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
Get:2 Index of /debian buster InRelease [122 kB]
Get:3 Index of /debian buster-updates InRelease [56.6 kB]
Hit:4 Index of /osmc/osmc/apt buster InRelease
Reading package lists… Done
E: Repository ‘http://security.debian.org buster/updates InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
N: Repository ‘Index of /debian buster InRelease’ changed its ‘Version’ value from ‘10.10’ to ‘10.13’
E: Repository ‘Index of /debian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
E: Repository ‘Index of /debian buster-updates InRelease’ changed its ‘Suite’ value from ‘stable-updates’ to ‘oldstable-updates’
osmc@Vero4k:~$ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
armv7-libass-osmc armv7-libnfs-osmc dh-python gnupg-agent libbind9-140 libcdio13 libcryptsetup4 libdevmapper-event1.02.1 libdns162 libenca0 libevent-2.0-5 libicu57 libisc160 libisccc140 libisccfg140 libiso9660-8 liblvm2app2.2
liblwres141 libncurses5 libntfs-3g871 libprocps6 libpython3.5-minimal libpython3.5-stdlib libssl1.0.2 libunistring0 libwebpmux2 python-apt python-certifi python-chardet python-dbus python-gi python-gobject python-gobject-2
python-idna python-imaging python-pexpect python-pil python-pkg-resources python-ptyprocess python-requests python-six python-unidecode python-urllib3 python3-distutils python3-lib2to3 python3.5 python3.5-minimal
wireless-firmware-osmc
Use ‘sudo apt autoremove’ to remove them.
armv7-bluezalsa-osmc libbluetooth3 libfdk-aac1 libpython3.7 libsbc1 python-crypto python-ldb python-samba python-tdb python3-dbus python3-gi python3-pil python3-unidecode samba-common-bin vero3-secureosmc-osmc
vero364-image-4.9.113-64-osmc:arm64
apt apt-utils armv7-bluez-osmc armv7-connman-osmc armv7-eventlircd-osmc armv7-network-osmc armv7-remote-osmc avahi-daemon base-files base-files-osmc bind9-host curl debian-archive-keyring libamcodec-osmc libapt-inst2.0 libapt-pkg5.0
libavahi-client3 libavahi-common-data libavahi-common3 libavahi-compat-libdnssd1 libavahi-core7 libbind9-161 libbsd0 libc-bin libc-l10n libc6 libcurl4 libdns1104 libgcrypt20 libglib2.0-0 libgnutls30 libgssapi-krb5-2 libhogweed4
libisc1100 libisccc161 libisccfg163 libk5crypto3 libkrb5-3 libkrb5support0 libldb1 liblwres161 liblz4-1 libmariadb3 libnettle6 libnss-myhostname libpam-systemd libpython3.7-minimal libpython3.7-stdlib libssl1.1 libsystemd0 libtiff5
libudev1 libwebp6 libwebpdemux2 libwebpmux3 libxml2 locales mariadb-common mediacenter-addon-osmc mediacenter-eventclients-common-osmc mediacenter-send-osmc mediacenter-skin-osmc multiarch-support openssl openvpn python3.7
python3.7-minimal systemd systemd-sysv udev vero3-bootloader-osmc vero3-device-osmc vero3-ftr-osmc vero3-libcec-osmc vero3-mediacenter-osmc vero3-userland-osmc vero3-wifi-osmc vero364-kernel-osmc:arm64 wpasupplicant
79 upgraded, 16 newly installed, 0 to remove and 0 not upgraded.
Need to get 10.6 MB/175 MB of archives.
After this operation, 153 MB of additional disk space will be used.
Err:1 http://security.debian.org buster/updates/main armhf libgssapi-krb5-2 armhf 1.17-3+deb10u2
404 Not Found [IP: 199.232.18.132 80]
Err:2 http://security.debian.org buster/updates/main armhf libkrb5-3 armhf 1.17-3+deb10u2
Err:3 http://security.debian.org buster/updates/main armhf libkrb5support0 armhf 1.17-3+deb10u2
Err:4 Index of /debian buster/main armhf base-files armhf 10.3+deb10u10
Err:5 http://security.debian.org buster/updates/main armhf libk5crypto3 armhf 1.17-3+deb10u2
Err:6 http://security.debian.org buster/updates/main armhf libbluetooth3 armhf 5.50-1.2~deb10u2
Err:7 http://security.debian.org buster/updates/main armhf python-samba armhf 2:4.9.5+dfsg-5+deb10u1
Err:8 http://security.debian.org buster/updates/main armhf samba-common-bin armhf 2:4.9.5+dfsg-5+deb10u1
Err:9 Index of /debian buster/main armhf libgnutls30 armhf 3.6.7-4+deb10u7
Ign:10 Index of /debian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u6
Err:10 Index of /debian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u6
Ign:11 Index of /debian buster/main armhf libtiff5 armhf 4.1.0+git191117-2~deb10u2
Err:11 Index of /debian buster/main armhf libtiff5 armhf 4.1.0+git191117-2~deb10u2
Err:12 Index of /debian buster/main armhf python3-pil armhf 5.4.1-2+deb10u2
Ign:13 Index of /debian buster/main armhf mariadb-common all 1:10.3.29-0+deb10u1
Err:14 Index of /debian buster/main armhf libmariadb3 armhf 1:10.3.29-0+deb10u1
Err:15 Index of /debian buster/main armhf libxml2 armhf 2.9.4+dfsg1-7+deb10u2
Ign:16 Index of /debian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:16 Index of /debian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:17 Index of /debian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:17 Index of /debian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:18 Index of /debian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:18 Index of /debian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:19 Index of /debian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:19 Index of /debian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:20 Index of /debian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:20 Index of /debian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:21 Index of /debian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:21 Index of /debian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:22 Index of /debian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Err:22 Index of /debian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Ign:23 Index of /debian buster/main armhf openssl armhf 1.1.1d-0+deb10u6
Err:13 Index of /debian buster/main armhf mariadb-common all 1:10.3.29-0+deb10u1
Err:23 Index of /debian buster/main armhf openssl armhf 1.1.1d-0+deb10u6
E: Failed to fetch http://ftp.debian.org/debian/pool/main/b/base-files/base-files_10.3+deb10u10_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/g/gnutls28/libgnutls30_3.6.7-4+deb10u7_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/o/openssl/libssl1.1_1.1.1d-0+deb10u6_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/k/krb5/libgssapi-krb5-2_1.17-3+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/k/krb5/libkrb5-3_1.17-3+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/k/krb5/libkrb5support0_1.17-3+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/k/krb5/libk5crypto3_1.17-3+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bluez/libbluetooth3_5.50-1.2~deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/t/tiff/libtiff5_4.1.0+git191117-2~deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/pillow/python3-pil_5.4.1-2+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/s/samba/python-samba_4.9.5+dfsg-5+deb10u1_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/s/samba/samba-common-bin_4.9.5+dfsg-5+deb10u1_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/m/mariadb-10.3/mariadb-common_10.3.29-0+deb10u1_all.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/m/mariadb-10.3/libmariadb3_10.3.29-0+deb10u1_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/libx/libxml2/libxml2_2.9.4+dfsg1-7+deb10u2_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/bind9-host_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/libbind9-161_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/libisccfg163_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/libisccc161_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/libdns1104_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/libisc1100_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/b/bind9/liblwres161_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/o/openssl/openssl_1.1.1d-0+deb10u6_armhf.deb 404 Not Found [IP: 199.232.18.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
osmc@Vero4k:~$
Blockquote
OK the hotfix url has expired. Maybe @sam_nazarko can remind us the cli commands you need. This might work: make a file
sudo nano /etc/apt/apt.conf.d/00-osmc-allow-suite-changes
with the following content
Acquire::AllowReleaseInfoChange::Suite "true";
quiet::ReleaseInfoChange::Version "true";
Then try to update-upgrade again.
But maybe you just have to reinstall Cannot update, even after hotfix - #3 by sam_nazarko
Thank you!
Kodi is now on status 10_2022.
I made a backup before reinstalling OSMC which I restored after installation. Unfortunately Kodi says that my library is empty. When I scroll to the movie-files and want to start a movie from there I only get a sad face.
Is there an easy solution, or is it better to dump the backup and populate the library completely new?
After you restore your backup you would need to delete the new versions of the database that automatically have been created on initial start. Then your old database should be automatically migrated to the new versions.
Check the files in ~/.kodi/userdata/Database
Thank you!
While checking the files you mentioned I realized and remembered that, long ago, I outsourced the database to an MYSQL Server on my NAS to allow access of both my Veros. After an firmware update, the OS of the QNAP does not support my version of MariaDB anymore. So this will be a bigger operation and I think I have to redo everything from scratch. Does sharing the Kodi library databases via the MySQL protocol work within Kodi 19?
KR
G
Both Maria / MySQL should work just fine
