Hi all,
For some reason my vero 4k is now crashing at all times when entering anything in the menu.
As a matter of course I have completely reset to device to stock from USB and loaded into the default osmc and it’s still happening.
Steps:
Switch the device on
Menu loads
Click on videos
The device shows a command prompt window and them the screen goes and stays blank
I then have to switch off the device and then try again.
I can’t wait or use anything, it just crashes from every option on the main menu.
Any thoughts?
