Vero 4k does not boot anymore
Hi after several years without any problems, my Vero 4k does not boot anymore.
I already tried to reinstall and to reflash both with an USB stick and a sd card.
Nothing did work.
Do I have another chance?
The power supply seems so be ok. 5.3 Volt should be good enough.
Holger
BTW: LED is blue.
Try on another display as a first step,
Tht’s it. Great, thank you very much.
