Its quite annoying, that after a fresh install, my Vero 4K+ went into a loop cycle when my USB HDD dock was connected with 2 HDDs. As there was no solution for this problem, I decided, to connect the USB Dock to my QNAP NAS as an external HDD, and install the Vero to use the NAS as a Media Library (SQL Server) and all the connected hard drives as media source - opening the opportunity to add one more Vero 4K+ in the future for my setup easily.
A quick summary: Nothing works… I created a user and a new database on the SQL server, and set SQL server in MyOSMC to look for (and create) the Library on the NAS. This resulted a 5-10 minutes hang with a black screen when booting up - assuming the Vero wants to connect to the SQL database without any success. However the MyPhPAdmin shows, that 2 connections are active (Movie, and Music library?)
Then, I wanted to add the network shares where my movie files are, but Vero cannot find any SMB or NFS shares at all. These shares are visible to my Windows 10 Pro PC, including the NFS share.
While It shows my QNAP (SAMBA) in the ZeroConf Browser, but when I click on it, it says “No route to host.”
Can someone help me out why nothing wants to work with this media player now?
Thanks in advance,
Csaba
Hi Sam,
Yes my NAS has a fixed IP, can you please guide me where can I find any logs with regards this problem, I only see the error message that Vero cannot reach the host.
I tried to manually enter the server address psw etc, with no luck. Interestingly the NFS browser pulls up my Popcorn A500 from the network as an NFS host, but not the QNAP.
reproduce the issue
Hi Guys,
OK, so I went back with a fresh install again, followed the guide and created the MySQL user with full privileges, and the problem is the same. OSBC hangs after the blue Logo screen on a black screen for 5 to 10 minutes - while there’s some communication in the background with the QNAP SQL Server - but no database or tables were created, and thats it. Still can’t reach any shares either on my NAS. So, it seems Vero cannot connect to my NAS at all. (installed its SMB client as well).
I was just about ordering another Vero to be able to use a multi room system, but I’m struggling with this since 3 days now without any success.
I followed Tom_Doyle’s settings, created the Debug Log and uploaded from My OSBC.
Please find it here: Event Log
Can't connect to MySQL server on '192.168.1.250'
Are you sure you allowed acces for the user kodi from all hosts?
Suggest you connect to the Vero via SSH and run mysql client to check. sudo apt-get install mariadb-client mysql -h 192.168.1.250 -u kodi -p
Then enter your password and if you get access run show databases;
Hi fzinken,
Thanks for that. I tried to connect, but it returned Can’t connect to MySQL server on … (115)
I have no idea what blocks the connection to the NAS, I created the kodi user, with % host, and gave ALL PRIVILEGES and GRANT as well. I even tried to add this user with the exact HOST IP address of my Vero, but no luck.
I’m not sure if it helps, but I also used the ping 192.168.1.250 on Vero, but just stopped responding, however pinging my router on the network ping 192.168.1.1 works without any problem.
So somehow my NAS is not visible for the vero, all other clients answers to the ping.
Ok good sign that the server is running and reachable.
But "Can’t connect to MYSQL ` is still a very low level error. You need to check your Server config. Can you reach the MySQL server from your other machine (via MySQL client)?
If it can be a useful information,
My NAS connected to the router with Port Trunking - with 2 ethernet cables using IEEE 802.3ad standard. In the NAS Network settings I can see its MAC address (ethernet 1 port).
OK, I removed that trunking, and arp -n reported the MAC address without any problem. And nmap also reached the NAS now!Than
Many thanks for your help to guide me to the solution!
Now everything works just fine!
Cheers!
