Hello, since yesterday I have a problem that is new to me. When Im watching a TV show (MP4), that is on my HDD (WD Elements Desktop), every second episode will not shown a picture but sound. This means, the first movie or picture will be fine (video / audio works) but the second file I want to play will be audio only without a picture
Workaround. I have to press play on my Harmony Elite Remote (with X-Box Profile), then press Return, press Play again.
Is there anybody here who is able to identify this behaviour. It is strange because it is completely new to me. I have not experience this before.
Dear Sam, thanks for your quick reply. It doesnt matter which file I want to play. Other workaround is to pull the power cable. After it, it will also play the first file but not the second (a movie or whatever). It is strange becauseI have never had this behaviour before. Maybe I have to test it with another HDD…
I think I will submit a support request as ActionA described.
Thanks Joakim. No I have not installed x-windows. Ive made no changes to the system and from day to another it occurs as described. Maybe I will reinstall OSMC as a fresh version. However, there is a workaround…
I believe this occurs for clips with high # of ReFrames. If so, I think there is something we can do to solve this. MediaInfo on an affected file could be useful. If you’re not sure how to do this just wait and see if it’s resolved in a future version of OSMC.
@joakim_s I have used the Exit Button of Kodi and it looks like that the Problem is gone. If temporarily or forever - we will see. Strange @sam_nazarko Thanks again for your engagement in this topic. I will try to get the Media Information.
PS. This community is amazing. I have never seen something like this before. Product Support at is best and helpful people. Sam and all the other guys. Thanks. Great!
Hopefully we can get this solved soon, and even better if we can get it solved without needing further info. A member of our team (@joakim_s) is also experiencing this. So not to worry: it will be solved, and promptly.
I had some files where audio would play but video would get stuck just few frames into the video. Disabling amcodec in settings -> player fixed the issue for me. ( Remember to re-enable it for usual videos)
Yep. Thanks @newsy This workaround works exactly as described. It is true I also have to start every movie twice but it is more comfortable as the other workaround “Exit Kodi”. Thank you!!!
