Show a screenshot of the USB stick so we can confirm you’ve imaged it properly.
You shouldn’t need to use the button.
Have you also tested with another device, such as an SD card, to make sure it isn’t just a problem with this USB stick?
I figured it out. For some reason it didn’t like the image I downloaded. When I selected the latest one in the installer it worked.
