Just tried the Gb usb adapter and got the following. Unfortunately now none of my 4k BR rips play. I only get a blank screen 1080p files play normally. Are there other changes I need to make for the Gb usb adapter?
osmc@vero4k:~$ dd if=/mnt/4kmovies/Exodus_UHD_HDR_Exodus_draft.mp4 of=/dev/null bs=1M count=3072 status=progress
249561088 bytes (250 MB, 238 MiB) copied, 6.01077 s, 41.5 MB/s
245+1 records in
245+1 records out
257805374 bytes (258 MB, 246 MiB) copied, 6.19385 s, 41.6 MB/s
osmc@vero4k:~$
Suggest to check that your GB connection is properly and all others are disabled. Share: ipconfig
And also install ethtool sudo apt-get install ethtool and check the negotiated protocol ethtool ethX
ethtool installed but it didnāt like ethtool ethX
osmc@vero4k:~$ sudo apt-get install ethtool
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
The following packages were automatically installed and are no longer required:
armv7-libcrossguid-osmc bluez libapt-inst1.5 libbind9-90 libdbus-1-dev libdns100 libdpkg-perl libgif4 libgnutls-deb0-28 libhogweed2 libicu52 libisc95 libisccc90 libisccfg90 liblwres90 libmicrohttpd10 libmysqlclient18 libnettle4 libntdb1 libplist2 libpng12-0 libpsl0 libssl1.0.0 libwebp5 libwebpdemux1 libwebpmux1
libxtables10 pkg-config python-dbus-dev
Use āsudo apt autoremoveā to remove them.
ethtool
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
Need to get 107 kB of archives.
After this operation, 302 kB of additional disk space will be used.
Get:1 Index of /debian stretch/main armhf ethtool armhf 1:4.8-1+b1 [107 kB]
Fetched 107 kB in 1s (87.8 kB/s)
Selecting previously unselected package ethtool.
(Reading database ⦠24936 files and directories currently installed.)
Preparing to unpack ā¦/ethtool_1%3a4.8-1+b1_armhf.deb ā¦
Unpacking ethtool (1:4.8-1+b1) ā¦
Setting up ethtool (1:4.8-1+b1) ā¦
osmc@vero4k:~$ ethtool ethX
Settings for ethX:
Cannot get device settings: No such device
Cannot get wake-on-lan settings: No such device
Cannot get message level: No such device
Cannot get link status: No such device
No data available
Regardless of which audio track you listen to, every track is sent over the Ethernet, and the Kodi player demuxes it on the Vero 4K. Because of the way the tracks are interleaved in the file, itās basically impossible to read only the tracks you want to watch/listen to/read.
So, the most important number you can get easy access to is the total average bitrate of the file. This doesnāt tell you if there is a spot in the file with a much higher combined bitrate, but a peak can never be more than 105Mbps for a rip from a 50GB disc, and never more than 128Mbps in any case.
I agree there, maybe it is any issue with ethtool but would wonder.
So means your issue must be something else. How do the 4k files play from local emmc or USB?
I upgraded to the January release and did some more testing trying to troubleshoot my problem of not being able to play 4k HDR since installing a GB network adapter. If I change the resolution to 3840x2160 in system settings everything plays including Lucy. However, I do get occasional momentary audio dropouts. Iām not sure why that resolution would make a difference, maybe thereās something else that got changed or messed up. Help appreciated.
Iām getting frustrated with this device. I followed the instructions above and canāt get it to boot from USB. Tried 2 different sticks and renaming kernel.img to recovery.img. The instructions say to hold down a button but I donāt see one.
