Great, thanks! Is there a guide on how to install?
There will be when itâs published, yes.
Cant wait for the public test!
Hi. Was this ever fixed/solved? Talking about the output of correct 4K HDR Infoframe metadata. Thanks
Yes. This has been solved in the 4.9 kernel.
How do you view the metadata? My JVC projector isnât showing it as being received, - just blank entries for MaxFALL/CLL.
No idea about on the JVC. I believe we log it in the system journal though.
Not sure I understand how to access that on the fly so I can set my projector up correctly based on 1000/4000nit media.
via ssh journalctl -f
I see⌠well⌠I guess that wonât be too useful when Iâm just wanting to watch a movie. May as well use MediaInfo at that point! Is there no way to get the info out to the display device?
If MaxCLL/MaxFALL is in the stream, we will send it.
Can you by any chance name a 4K movie that passes that data so I can check? Iâve only tried a few but so far⌠nothing.
Alita has it
Alita has it
Thanks. Will check shortly.
Has the JVC ever shown that data?
We are definitely passing through the metadata.
Can you post a log so I can see what software youâre on?
We are definitely passing through the metadata.Can you post a log so I can see what software youâre on?
Iâm on the January 2020 update. Havenât installed March yet. And yes, with my OPPO player I get that data. My Apple TV 4K also passes that data and I see it, though I believe itâs not technically correct because the Apple TV maps everything to 1000 or 4000 (I canât remember which).
Has anyone else gotten this to work?
If youâre on the January 2020 update you havenât got the 4.9 kernel installed.
Did you follow the 4.9 installation instructions?
Without 4.9, you wonât get MaxFALL or MaxCLL through.
Youâve been living under a rock.
Details are here: [TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
HDR10+ and HLG are now supported as well.
Good lordâŚ
I think what happened is I read this under the January, 2020 post:
- Add initial support for 4.9 kernel on Vero 4K/4K+
And was like, oh sweet - 4.9 is out. I guess I actually have to do more than just get the January update.
