Me again…
Kodi is crashing and crashing and crashing again…
I have disabled all extensions (except those for scraping Movies, Series and Music), but no way…
I still don’t get how to use this command in order to provide a filtered log:
grep ‘11:36:40’ .kodi/temp/kodi.old.log
More, I had have this strange behaviour: Cleaning library erased all files and as all these issues happened since the last update I wonder if I need to reset OSMC and Kodi.
I see you’re using skin “Aeon Nox: SILVO”.
Just for tests could you switch to the OSMC skin and verify these crashes still occur?
With that you know it is skin related or not.
Yes I know the desktop skin selected on the TV is aeon.nox.silvo.
I use the web interface on my laptop to tune OSMC/Kodi options. It’s easier for me to do that with a mouse than the remote. So when I have asked for a resume that window this text appears
"Resume from <strong>08:50</strong> <small>8% complete</small>"
In order to attempt to resolve the “Vero 4k Kodi19 rebooting every night” issue, you are being asked to change the GUI back to the OSMC skin and see if the issue persists.
This is your problem you would like addressed, no?
We don’t care about the web interface issues until we solve the primary problem.
I’ve changed the GUI back to the OSMC skin.
It crashes and as I said I can no more provide a log.
As those issues appeared after the last OSC/Kodi update I asked if I can make a fake reset in order to ask in My OSMC for a manual update to overwrite the whole enchilada.
