Vero 4K+ messes with ARC
I just had my third ARC failure in almost a year of Vero ownership. The incidents are a bit scary, as ARC is killed completely, and recovery inolves a lot of disconnecting and hoping, just taking out the power does not always work. Anyway, back up and running now. No other device connected to my AVR ever causes this trouble.
Unfortunately it’s going to be a bit of a sod to diagnose something with such infrequency.
Do you have a log for this?
Unfortunately no log. I think I’ve figured out if I pull the power to the AVR completely and remove the Vero’s HDMI lead, the TV’s ability to see the AVR comes back. If I just unplug the Vero the ARC stays dead. Since this is such an infrequent problem I can live with it (twice with a regular Vero4K, now first time with a 4K+). Appreciate without some specifics on the circumstances leading up to the ARC crash, this will likely remain a mystery.
I have a similar issue with my Vero 4k. It appears to interfere with the ARC (and the CEC) functionality of my TV set (Philips 55pos9002).
Set-up:
  • my Vero 4k is directly connected to one of the HDMI ARC inputs of my TV set (Philips 55pos9002). I’ve tried multiple HDMI cables with different lengths. The TV set has two HDMI ARC inputs; I tried both.
  • A Philips sound system is directly connected to another HDMI ARC input of my TV set
Behaviour:
  • Everything is working fine as long as I do not connect the Vero 4k to the HDMI ARC input of the TV set
  • However, it appears that the Vero 4k is interfering with the other components. This might not happen right away but usually pretty soon after plugging in the Vero 4k.
What do I mean with interference?
  • After connecting the Vero 4k to the TV set, the TV fails to activate the sound system, meaning that it outputs the sound through the speakers of the TV set. When trying to change the output in the settings of the TV set I receive a notification that it cannot activate the sound system
  • When switching off the TV set (since it’s a OLED, it is actually not turned off but sent into a sleep mode) the sound system is not put into sleep mode (i.e., the Vero 4k appears also to interfere with CEC since this is working flawlessly if the Vero is not connected).
  • The sound system is not activated when turning on the TV
  • What is strange is that I don’t even have to switch to the Vero 4k. The problem also occurs if I only plug-in the Vero 4k and only watch regular TV, Netflix, etc.
  • It will very often lose ARC when changing source to Vero 4k.
Problem solving
  • When the TV set is failing to activate the ARC of the sound system then it is not sufficient to power off (i.e. plug the power cords) of the TV set, the Vero 4k and the sound system and to wait for 20 seconds. The problem is still present after truing on / booting the devices
  • To be able to activate the sound system I have to plug-out the HDMI of the Vero 4k and to reboot the TV and the sound system.
I really would appreciate help. Currently, I cannot use my Vero 4k; it is just sitting next to my TV and is neither connected to a power socket or my TV, which is a bit of a waste of such a nice peace of hard/software.
Please advice on logs etc.
Best, Markus
Hi, had some CEC and ARC related issue with my setup as well, you’re welcomed to try the beta fix provided by @sam_nazarko if you’re confident enough.
ARC should only really present problems if something is turned off. If everything is on, then things should be working well.
Thanks Sam.
I’m not sure that I can follow. My problem is that when turning on the TV the TV cannot activate the sound system, meaning, that it uses it speakers and not the sound system as the output device. The other frequent problem is that when changing source e.g. from ordinary TV to Vero 4k then there is no sound at all. My guess is that this is also related to the issue that some CEC functionality does not work either, since the sound system does not go into stand by after turning off the TV.
Cheers, Markus
I’m not sure that CEC would be the culprit here but you could try the above
Thanks Sam.
I did have the time to try jaybird’s suggestion yet.
Today I turned my Vero 4k on and checked /etc/apt/sources.list on my Vero 4k and the line deb http://apt.osmc.tv stretch-devel main was already on the list.
I guess this means that I already have installed the beta fix as suggested by jaybird, right? (since I have installed all updates prompted in OSMC.)
Anything else I can try? (The current situation is that I’m not using my Vero 4k any longer due to the ARC problems. My Vero 4k is just sitting next to my TV powered off, which is a real bummer)
Best, Markus
Have you tried the Vero connected to one of the non-ARC HDMI connections? ARC is for a device that sends and receives audio. The Vero will only send and that may be confusing the TV.
Sorry, my mistake: all HDMI connections support ARC. The configuration is as follows:
• HDMI 1: ARC, MHL, Ultra HD, HDR
• HDMI 2: ARC, Ultra HD, HDR
• HDMI 3: ARC
• HDMI 4: ARC
The Vero 4k is currently connected to HDMI 2 but I also have tried HDMI 1.
FireStick 4k ==> HDMI 1
Vero 4k ==> HDMI 2
Nintendo WII ==> HDMI 3
Soundsystem ==> HDMI 4
Best, Markus
I think you are mistaken about ARC. Normally, TVs normally have 1 ARC on HDMI2. And it’s interesting that that’s where you have the Vero connected. Try swapping the Amp on HDMI4 with the Vero and see what happens.
Okay, after following jaybird’s suggestion…
… my Vero 4k crashes after c. 30 seconds, reboots, and crashes again in a continuous loop.
I have to reinstall OSMC for better or worse, or is there another possibility?
I installed and activated the Backup Plugin. Hope that this will work relatively quickly. with that said, I don’t have time today (have to do my taxes and hope to spend some quality time with the kids).
Markus
Quoting the manual of the TV: HDMI ARC (p. 25 https://www.download.p4c.philips.com/files/5/55pos9002_05/55pos9002_05_dfu_eng.pdf): “All of the HDMI connections on the TV have HDMI ARC (Audio Return Channel).”
According to the manual only HDMI 1 & 2 have Ultra HD capability. Probably does not make sense to connect the Vero 4k to a non 4k HDMI as this defeats the purpose of having a Vero 4k.
Best, M
Crashes or Kodi is restating with a sad face?
If it’s a sad face we can probably work that out.
It stops with a sad face (from the appearance I’d say that OSMC crashes not Kodi) and then it reboots.
M
Ok, then try: Vero: 1, Soundbar: 2, Firestick: 4 and see what happens.
Sad face is Kodi crashing. Are you actually seeing the boot sequence or Kodi just starts again?
Interesting read of the manual:
But once you have
connected the Home Theatre System, the TV can
only send the ARC signal to this HDMI connection.
I wonder if the TV is getting confused.
You are correct. Kodi is rebooting (I have an active terminal connection to Vero and it does not shutdown).
So, is there a way to rescue the system?
M
