Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
python-samba samba samba-common samba-common-bin
Use 'sudo apt autoremove' to remove them.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up samba-common-bin (2:4.9.5+dfsg-5+deb10u1) ...
Checking smb.conf with testparm
Load smb config files from /etc/samba/smb.conf
Error loading services.
dpkg: error processing package samba-common-bin (--configure):
installed samba-common-bin package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of samba:
samba depends on samba-common-bin (= 2:4.9.5+dfsg-5+deb10u1); however:
Package samba-common-bin is not configured yet.
dpkg: error processing package samba (--configure):
dependency problems - leaving unconfigured
samba-common-bin
samba
And then
sudo apt-get --reinstall install smb-app-osmc
gives
smb-app-osmc
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/3484 B of archives.
After this operation, 68.6 kB of additional disk space will be used.
samba-common-bin
samba
Ok, suggest to carefully try to remove samba-common-bin as soon as you see a warning about a Vero package being removed say no. sudo apt-get purge samba-common-bin
If that goes without issue try again sudo dpkg --configure -a sudo apt-get -f install sudo apt-get --reinstall install smb-app-osmc
Here is the output from the 4 commands in your last post:
osmc@osmc-oggie:~$ sudo apt-get purge samba-common-bin
python-samba samba-common
The following packages will be REMOVED:
samba* samba-common-bin*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 16.9 MB disk space will be freed.
(Reading database ... 29669 files and directories currently installed.)
Removing samba (2:4.9.5+dfsg-5+deb10u1) ...
Removing samba-common-bin (2:4.9.5+dfsg-5+deb10u1) ...
Processing triggers for libc-bin (2.28-10) ...
(Reading database ... 29424 files and directories currently installed.)
Purging configuration files for samba (2:4.9.5+dfsg-5+deb10u1) ...
Processing triggers for systemd (241-7~deb10u7) ...
osmc@osmc-oggie:~$ sudo dpkg --configure -a
osmc@osmc-oggie:~$ sudo apt-get -f install
osmc@osmc-oggie:~$ sudo apt-get --reinstall install smb-app-osmc
The following additional packages will be installed:
samba samba-common-bin
Suggested packages:
bind9 bind9utils ctdb ldb-tools smbldap-tools ufw winbind heimdal-clients
Recommended packages:
attr logrotate samba-dsdb-modules samba-vfs-modules
samba samba-common-bin smb-app-osmc
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1606 kB of archives.
After this operation, 16.9 MB of additional disk space will be used.
Selecting previously unselected package samba-common-bin.
(Reading database ... 29417 files and directories currently installed.)
Preparing to unpack .../samba-common-bin_2%3a4.9.5+dfsg-5+deb10u1_armhf.deb ...
Unpacking samba-common-bin (2:4.9.5+dfsg-5+deb10u1) ...
Selecting previously unselected package samba.
Preparing to unpack .../samba_2%3a4.9.5+dfsg-5+deb10u1_armhf.deb ...
Unpacking samba (2:4.9.5+dfsg-5+deb10u1) ...
samba-common-bin
samba
Alternatively create a smb.conf in /etc/samba/ with this content
[global]
# If you require a fully custom smb.conf create smb-local.conf instead of editing smb.conf so your
# configuration will not be overwritten by samba upgrades. You can use smb.conf as a template by
# copying it to smb-local.conf then removing the config file line below in the new file. If you only
# need to add some additional shares see smb-shares.conf below for a simpler way to do this.
config file = /etc/samba/smb-local.conf
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
fruit:model = Macmini
# usershare template share = automount template
# Automount template disabled to work around a samba bug causing crashes accessing external drives.
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
comment = OSMC Home Directory
[automount template]
browseable = yes
-valid = no
valid users = osmc
path = %P
hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
The following package was automatically installed and is no longer required:
samba
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/170 kB of archives.
Preconfiguring packages ...
(Reading database ... 29668 files and directories currently installed.)
Preparing to unpack .../samba-common_2%3a4.9.5+dfsg-5+deb10u1_all.deb ...
Unpacking samba-common (2:4.9.5+dfsg-5+deb10u1) over (2:4.9.5+dfsg-5+deb10u1) ...
Setting up samba-common (2:4.9.5+dfsg-5+deb10u1) ...
Not replacing deleted config file /etc/samba/smb.conf
Install/upgrade will fail. To recover, please try:
sudo cp /usr/share/samba/smb.conf /etc/samba/smb.conf
samba-common-bin
samba
I’m back in! I figured that the username and password would revert to default after reinstalling samba and sure enough I was able to log in on my wireless devices using osmc for both. Strangely, I can still access all my Vero shares on Windows without changing anything.
How can I change my samba password to match with the password that I use for SSH?
Old SMB password:
New SMB password:
Retype new SMB password:
SAMR connection to machine 127.0.0.1 failed. Error was NT_STATUS_ACCESS_DENIED, but LANMAN password changes are disabled
