I have a vero 4K+ and lately I’m having some problems with it, like the iptv channels don’t load and it doesn’t recognize my external hd (Seagate 4tb) where I have all my movies. I have reinstalled the OSMC, but it didn’t solved the problem. I need some help figuring out what’s happening!
Meanwhile I bought a USB powered hub to connect the HDD and while now the Vero can load the library, it still doesn’t upload the channels all the time.
Now also, out of nowhere it stops working. It shuts down and the red light doesn’t even turns on.
Can someone help me with this issue please?
Cheers!
Are you using an OSMC powered hub?
What are the specs of the hub? It might not be providing enough power; or it may be backfeeding the Vero.
Does the Vero work with the hub connected, no PSU connected, and no HDD connected?
There’s also another issue, when listening to music from the HDD with or without the USB hub, after 3 or 4 songs the Vero shutdown and reboots…
Please answer this.
It sounds power related
Yes it does. And now, with no hdd or usb hub, the vero shutsdown. Sometimes at the begining some times a little later…
Your hub is backfeeding the Vero then.
Would need to see logs.
Ok, I’ll need a little help there.
How do I see and send you the logs?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
thanks, I’ll try to do that just now
The vero doesn’t start now. I don’t have anything attached to it, but as soon as I power it, it shutsdown.
In what configuration?
Disconnect everything from the Vero except the remote dongle and official power supply and then try.
Thats how it is, with nothing connected.
If you are not using the official powered hub, and it was powering the Vero without the attached power supply, it was likely backfeeding the device.
Hopefully you didn’t have both the supplied PSU and hub connected at the same time.
Leave it off for half an hour, and then try again.
So now I blew this up. Tried to reinstall the OSMC and failed and now it says fatal error could not find root…
damn…
Leave it off for half an hour.
Boot using only the official PSU and device, no hub.
Reinstall OSMC from Download - OSMC.
That’s what I did, but I’ll wait half an hour and try again…
