Got my Vero 4K+ a couple weeks ago, and I guess I’ve only watched 1080p content so far. I just tried to fire up a 4K/HDR movie, it said ‘buffering’ (for a second as it loaded), appeared to start playing, but wasn’t showing me any video or outputting any sound. Tried a 1080p ISO, no problem, tried another random 4K/HDR file, same deal, won’t play it.
Read a couple threads here, made sure all my settings align with what is recommended, still the same thing. Tried 422 even though I’ve never had to set that with my U9-H or the NUC I was using briefly - still didn’t solve anything.
As a first check I suggest to check your network speed (also as you are using WiFi do you have a 5Ghz network and are you using different SSID for 2.4 and 5 GHZ?)
osmc@osmc:~$ iperf -c 192.168.0.55 -p 5050
Client connecting to 192.168.0.55, TCP port 5050
TCP window size: 85.0 KByte (default)
[ 3] local 192.168.0.187 port 54304 connected with 192.168.0.55 port 5050
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 275 MBytes 230 Mbits/sec
osmc@osmc:~$ iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[ 4] local 192.168.0.187 port 5001 connected with 192.168.0.55 port 51500
[ 4] 0.0-10.1 sec 250 MBytes 208 Mbits/sec
^Cosmc@osmc:~$
This is not a new setup. The Vero 4K+ is a drop-in replacement for a U9-H that was running CoreELEC, and everything worked flawlessly with that setup. I wanted frame-packed 3D though so I switched to a Vero and gave the U9-H to my son.
Plays back without issue on my Windows laptop w/ MPC-HC. The other file that is causing the same issue I have watched in full on a U9-H w/ CoreELEC.
I have a 1m sample ready to upload! Just say where!
I would be more than happy to try. I was poking around trying to see if I could download a nightly or beta from somewhere or build one from Git but couldn’t find anything that said “This is the 3D stuff, install this!”
Full disclosure: I’ve got a USB DAC hooked up to this box and squeezelite running in the background 24/7. I can’t imagine that would cause any problems, but it seems worth mentioning. My output device is set to HDMI and I passthrough everything.
Ah! Ok, copied it over to a USB drive, and just gave it a go … exact same thing … ‘Buffering’ for 1-2 seconds while it loads, then the OSMC logo dancing in the middle of the screen while the timer counts up in the background as though it is playing.
TY for the upgrade instructions, I’ll get started on that right now.
Oh that’s interesting … it’s doing the same thing to me on 4.9 as everything was doing on 3.14. I, didn’t actually make the sample … taps his nose … very odd.
