I have the problem that every time i start my Vero 4k+ the pairing to my Logitech Harmony Elite is lost - i have to sop/start the bluetooh service and start/stop the discovery - then the Harmony is back again under Paired Devices… not sure if this probem occured since the last OSMC Update - all my other devices works well with the Harmony, so this problem must be Vero related… i have no idea what i can do to solve this…
@sam_nazarko… the problem occurs again… start/stop the discovery doesn´t work - i have to disable and enable Bluetooth and then start the discovery to find the Harmony again… any ideas?
This happened to mine on Friday, it had been working fine for 2+ years. I too had to disable/enable bluetooth on the Vero to re-connect. I’ve not tried to see if it’s lost again on reboot, will do that today.
Yeah mine is same, I lose the bluetooth pairing on reboot. Here’s a debug log, when I enabled debugging and rebooted I did see a BT error on screen before turning off, weirdly though, the pairing seems to work when rebooting with debug on.
At the moment it works after disable and enable bluetooth yesterday so i think the problem occurs after some time again or so… i will collect the logs when the connection to my harmony is lost again…
I thought I was, March 2020-03.1. Went to manually update and there was an update, which I applied, but still showing the same version number, is that correct?
