The remote that came with my Vero 4K + stopped working a while ago. I replaced the battery (the old one had not leaked and was still good), but this didn’t change anything. I can still use my Vero 4K+ via HDMI-CDC with the remote of my LG TV. But I’d very much like the original remote to work, even though I figured out how to do things not possible with the LG remote using a USB mouse (right-click, for example).
This is what I tried:
Battery is brand new
blue light on the remote comes on when any button is pressed
with USB receiver unplugged, when I press Home and OK simultaneously, blue light comes on after a few second and stays on. I tried this many times, behavior always the same, which is different from which is described in other threads
when I then re-plug the USB receiver in either USB slot, nothing happens
When I press a button on the remote and immediately release it, the blue light comes on and stays a tiny bit longer than the button is pressed, but only for a fraction of a second (maybe 1/4 second).
I haven’t tried on another device yet, mainly because the only devices I have are iMacs. I just plugged it into my 2017 iMac and the Keyboard Setup Assistant came on telling me that “Your OSMC Remote Controller device cannot be identified and will not be usable until it is identified”.
Does that tell us anything regarding the operability of the RF receiver?
That means the remote is communicating with the receiver.
No – you should be able to scroll a web page up / down using the arrow keys as you would on a keyboard. For macOS, there are additional steps to make the remote work fully.
I don’t have any extra insight here regarding your OSMC remote but you don’t need to use a mouse to add functions to an LG remote controlling Kodi via CEC. You can use the Keymap Editor add-on to remap buttons to different functions. Specifically the << and >> buttons on your remote are likely a good place to map “context menu” and “info” to. If your remote has the red, green, yellow, and blue buttons these will likely be forwarded via CEC as well and thus available to repurpose.
Thanks for that, I just changed the blue button on the LG remote which now brings up the context menu (hint: Keymap Editor - Edit - Global - Navigation - Context Menu).
But I still would like to find out why the RF Remote stopped working. I guess I‘ll have to find a PC, haven‘t seen any in years.
For more information about getting it to work on macOS see OSMC Remote Control + macOS + Kodi issue. But this was tested with what is now quite an old version of macOS and the security model has changed a bit, so this program may not be applicable anymore.
