Ordered 30th July and status is packaged. Its getting closer!!!
I got mine on the 11th (ordered July 13th).
Iām curious; are everyoneās USB ports upside down?
Well basically you could say all ports (other than the ethernet) are upside down based on the design how the board is installed in the case.
I ordered on the 14th, and tbh Iām expecting a longer wait than that.
heh. Even I got min (Order status processed), and I had expicitly told Sam to not worry about my shipment as all my systems work well, and there are some kidās out there ABSOLUTELY wanting theirs
Anyway - Thx Team!
14th July? I would have thought yours will have been shipped by now. Or did you think he put 14th August? ![]()
No August, I ordered on the 14thā¦, he ordered on the 16th August.
Are you talking about me? Yes i ordered on August16th, of you ordered on the 14th of August yours should be up earlier than mine.
Yeah thats right, I think the other guy made a mistake.
Remember Sams now in the period where sales went through the roof so I think 3 weeks could be a bit optimistic.
Im using a Pi3 with a suspect SD card atm, it crashes and locks up daily⦠Im hesitant to replace the card as the 4k+ will mean I wonāt need the Pi3.
Iām using an Eminent EM7680, 1080p no problems, but UHD movies it hangs and stutters.
It had a 100mb ethernetport and 1 Gb Ram, the Vero 4k+ doubles that so i hope my problems will be solved.
Sam and his team never expected the sales to go through the roof and thatās why we have to wait.
Iām sure that if they had known it wouldnāt have come to this.
No as it was explained by Sam the issue was a hicup at the customs which delayed a huge delivery that was expected in June/July but only arrived in late August.
Sorry 'bout that, i must have missed that. This topic is getting longer and longer.
I ordered mine on the 12th August and it is still processing but like Sam said the actual order number doesnāt necessarily mean the order in which they came in.
I didnāt make a mistake. There are 12 ā14thā days in a year. If there is not a month next to it then it could be any of them! ![]()
Considering I was replying to a guy who specifically mentioned August it was pretty obvious what month I was referring to buddy.
I order mine 31st July. It is now ready for shipment.
Thank you OSMC team.
Got mine today. July 25 order. Norway. I think it slipped though the customsā¦sweet.
Thatās going to annoy @tor.gunnar.berland.
BTW: why is half of the population of Norway buying Veros all of a sudden? Is there a hardware or tech forum somewhere recommending this device suddenly?
Shhhh! Donāt tell him! ![]()
Got my 4k+ 2 days ago to Sweden (order @ July 25), just plugged it in to have a quick look and its a step up from my RPi3!
