I just updated to the December update and my surround sound has gone out on my LG sound bar. The sound worked flawlessly before the update in 2.0 and 5.1 but only the surround is coming out of the bar currently on 5.1 audio. If OSMC is switched to use 2.0 sound everything works perfectly.
My setup is the following:
LG 65EF9500 4K OLED
Vero 4K
LG soundbar LAS454B
Vero → HDMI → TV HDMI input → TV optical out → LG soundbar
I have tried 3 different HDMI cables and all 3 HDMI inputs on my TV,none of the settings on the soundbar make a bit of difference, and also nothing in the TV sound setup menus work.
I’ve had a similar issue since updating. I am using SPDIF into an old Onkyo receiver. I have Left, Right and Centre speakers connected only and had KODI audio output configuration set to 3.0 previously. After the update the sound was ‘washed out’ and very quiet. Only by setting KODI to 2.0 can I get anything resembling what I had previously. Not a massive issue, but it’s there.
Just to be clear - switching to 2.0 has ‘resolved’ it, but with nothing to compare it against I can’t say for sure if it’s comparable to when I had it set to 3.0.
Wow, call me shocked because having it set to 5.1 has always worked on my Shield TV, Intel NUC, and the Vero 4K up until now. I never looked at the specification on the soundbar but you’re definitely correct in it looks like 2.1.
update
Setting 2.1 in Kodi definitely works! Why would 5.1 work this whole time and now all of the sudden stop thou. I understand the bar is not 5.1 (thanks for that) but I’m left puzzled.
We had a problem where audio was incorrectly mapped on Vero 4K for a while.
Now that we’ve fixed it, it looks like we’ve exposed that your receiver only supports 2.1
It likely will support DTS and Dolby Digital; so it may be worth passing that through if it is indeed supported.
