On the latest OSMC version (and previous) I play certain files locally from an attached powered HDD. At a certain point the video will stop playing and will attempt to buffer while one of the CPU cores maxes out at 100%. I have to stop playback since the buffering never completes.
Attached are logs, but not with a restart after enabling (just a normal boot and enabling), since every time I enable logs and reboot, the exact same files play flawlessly and I cannot reproduce the issue.
https://paste.osmc.tv/jivohecozu
I can link media info about the files on request, but I can no longer find the wiki-page detailing the program to use (if someone can be so kind as to link me).
EDIT1: Just saw this thread; Recent Update Causes 1080p Stutter/Crash
There are no updates when running from MyOSMC. I will try SSH.
EDIT2: SSH update using sudo apt-get -f install doesn’t install or update any packages;
Reading package lists... Done
Building dependency tree... Done
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
