I have a Vero 4k running OSMC v18.6. (I’ve never been able to upgrade it since I bought it used in 2019 - have tried using hotfix and command line method without success.)
I only ever use Vero in ‘File Mode’ as a simple media player which allows me to browse my folders and files as set up on an ext hard drive. (I like to add customised artwork poster.jpg/fanart.jpg with movie information nfo brought in using tinymediamanager.)
I use the minimalist OSMC interface and I have all my settings backed up on an ext HDD via MyOSMC backup
My question: I’d like to switch to Vero V. Can I use this backup to transfer over to Vero V or is it too old?
So - I’ve accessed via ssh (terminal i’m on Mac) …
put in
sudo apt-get update
then
sudo apt-get dist-upgrade
with result:
“Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
The following packages will be upgraded:”
with the result: about 30 lines of upgrades
and hundreds of lines of Err with this at end
“unable to fetch some archives, maybe run apt-get update or try with --fix-missing?”
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Nov 9 16:52:31 2023 from 192.168.178.35
osmc@kodi:~$ sudo apt-get update --allow-releaseinfo-change
E: Command line option --allow-releaseinfo-change is not understood in combination with the other options
Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
Get:2 Index of /debian buster InRelease [122 kB]
Get:3 Index of /debian buster-updates InRelease [56.6 kB]
Get:5 http://security.debian.org buster/updates/main armhf Packages [563 kB]
Get:6 http://security.debian.org buster/updates/main arm64 Packages [559 kB]
Get:7 http://security.debian.org buster/updates/main Translation-en [307 kB]
Get:8 http://security.debian.org buster/updates/non-free armhf Packages [9,664 B]
Get:9 http://security.debian.org buster/updates/non-free arm64 Packages [5,204 B]
Get:10 http://security.debian.org buster/updates/non-free Translation-en [24.5 kB]
Get:11 Index of /debian buster/main arm64 Packages [7,737 kB]
Get:12 Index of /debian buster/main armhf Packages [7,706 kB]
Get:13 Index of /debian buster/main Translation-en [5,969 kB]
Get:14 Index of /debian buster/contrib arm64 Packages [38.4 kB]
Get:15 Index of /debian buster/contrib armhf Packages [40.1 kB]
Get:16 Index of /debian buster/contrib Translation-en [44.2 kB]
Get:17 Index of /debian buster/non-free arm64 Packages [53.9 kB]
Get:18 Index of /debian buster/non-free armhf Packages [62.1 kB]
Get:19 Index of /debian buster/non-free Translation-en [88.9 kB]
Get:20 Index of /debian buster-updates/main armhf Packages [8,784 B]
Get:21 Index of /debian buster-updates/main arm64 Packages [8,780 B]
Get:22 Index of /debian buster-updates/main Translation-en [6,915 B]
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
osmc@kodi:~$ sudp apt-get dist-upgrade
-bash: sudp: command not found
osmc@kodi:~$ sudo apt-get update && sudo apt-get dist-upgrade --fix-missing
Hit:1 Index of /debian buster InRelease
Hit:2 Index of /debian buster-updates InRelease
Hit:3 http://security.debian.org buster/updates InRelease
osmc@kodi:~$
No, worst case you have to make install media and start over. IMO your heading down the wrong path though. As I posted two days ago you can use a old backup on a newer install with a little more effort. My recommend would be to just use your current backup and restore that to your Vero V, Then ssh and run the commands I supplied in the other thread to get the library to upgrade, and then check everything to make sure your tickety-boo. The most you have to loose if somehow that goes sideways is needing to delete the .kodi folder to get back to defaults. At this point if everything is all good and you still want to use your Vero 4K I would do a clean install on it and then restore userdata on it from a backup you make on the newly configured Vero V.
