Just performed a clean install of OSMC on Vero 4K+. Mounted my fileshare via /etc/fstab (same as before clean install).
Pointed OSMC at my media, and all is looking great. However, if I go into menu customisation and widgets I’m stuck on “random movie”.
If I click on Add, new item appears. If I click on Widget the new window opens but I can’t do anything on the new screen.
I’m sure you would be able to browse other widgets, creating a smart playlist etc… but its just seemingly stuck
Want the widget to show recently added, unwatched movies .
If I can assume your running the OSMC skin then have you read through this…
As explained in the OSMC Skin wiki article , the main menu of the OSMC Skin can be customized entirely.
The customization process via the main menu customization dialog might take some getting used to as it offers a lot of ways to tweak nearly every aspect of the main menu. With this how-to we’d like to acquaint you with the customization dialog and the different ways it allows you to adjust the OSMC Skin main menu to your taste and needs.
For a quick explanation how to get to the main menu …
My issue isn’t “I don’t understand the process”, my issue is “the navigation is broken”. I can get so far into the menu system to “Add a new widget”, but then the menu system is completely frozen. I can’t physically make a change once into the edit.
sudo apt-get install --reinstall mediacenter-skin-osmc
This seems to have fixed it, I can now browse the menus - will see how it fairs. Strange for a brand new install from disk image (image was verified).
Menus briefly worked, now broken again.
Using the default Kodi skin. All seems good so far - feels like somethings broken in the default osmc skin.
Might be one for @chillbo to advise.
This should be fixed in our staging repo - it’s a bug I unfortunately overlooked for our last update. If you’d like to test:
This is due to a bug that was unfortunately missed when pushing the last update… We’ve got a fix ready for this. We’d appreciate it if you could test this and provide feedback. To test this:
Login via the command line
Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
Your system should have …
