Don‘t waste your time on experimenting on settings, I have tried literally everything and it is not about the settings. I am fairly confident that even on a fresh install with 18.2 you would experience the freeze.
It might indeed also be audio related, e.g. passthrough. Like audio and video not in sync after pause and the video is frozen while the player is trying to get them in sync again. But it could be something much different as well, but we better leave that to the experts.
Yes, it is new with the Leia update. I have paused thousands of movies and series for subtitle search (which almost always take 10 seconds or more for the whole process, opensubtitles is soooo slow) before Leia and I never had a freeze.
I know people incl. myself are always a bit grumpy when things are not working, but I really appreciate all the work you put into the device. Actually I am very pleased with the Leia update otherwise. I hope we provided you with enough info to identify the problem.
Just want to add my thanks as well. I always appreciate the care and support you put into these releases, and have no doubt you’ll figure this one out sooner or later!
I’ve also had the same issue but it’s sporadic and my makeshift solution is to click reverse (10 seconds) and it restarts the video at that point without issue.
I can‘t see that even as a makeshift solution. Watching the last 10 seconds again to avoid a 5 second freeze is like choosing between two bad options, one way or another it is annoying.
Here’s something that should help diagnose the issue further.
If instead of pressing pause, you just hit “Back” on your remote a few times to go back to the menu while the video is playing and then continue to press “Back” until it takes you back to the video, the exact same symptoms occur. The sound continues while the video appears paused.
I have tried to reproduce this, and have totally failed. I tried pausing a UHD movie for over an hour (up to 8 hours) and after the NAS mounted drive wakes up, the video continues like normal. I don’t know how many times I’ve paused BD and SD videos with no issues.
I tried what you suggested @Knocks, Back to the home menu, back to the video. Continues like it should.
My only guess is that there is some an add-on causing the issue.
I guess I didn’t clearly say this: I have tried to reproduce this with videos in 480 and 1080. And I can’t. I’ve paused videos overnight and they just always restart like they should (given the delay to wake up the drive)
And I tried your idea to go back to the main menu, and back to the video while it’s playing and I still can’t reproduce this.
There is something different in your setup. Please post full debug logs when it happens. Maybe we will be able to see what is different in you system vs. those of us who can’t reproduce this.
Looking back in this thread, I don’t see that @WilliamG or @Knocks have supplied logs showing what happens when you have the problem. So maybe logs could help…
