Is there any progress on a fix for this?Something that I could help out to test before it is released?
I purposely waited a few weeks with upgrading to V18 with the intention that minor things like this would surely been ironed out by now. Im aware that it is impossible to forsee everything and that there factors you’re not in control of, but for a stable release running on branded HW with optimized OS this is not impressing.
I can’t believe that a crucial function like pause/unpause that worked before has now become crippled, it is really irritating.
I know Sam is working on various video issues as we speak.
I have an idea on how to fix it but no way of verifying it. I have not been able to produce this issue whatsoever, and I’ve been using v18 for weeks as a daily driver.
I thought someone on the team could reproduce the issue. Can‘t you send him the possible fix?
Guys what screensaver do you use? It could have something to do with this.
It’s not that. I’m building a fix now.
Hopefully the issue is now addressed
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
I tried doing this (since I’m experiencing the problem) but upon playback, Kodi crashes. I see what appears to be the refresh rate change but it just comes back with the sad face.
My logs end with:
2019-05-16 20:25:00.963 T:3388957408 NOTICE: Creating InputStream
2019-05-16 20:25:01.280 T:3388957408 NOTICE: Creating Demuxer
2019-05-16 20:25:01.343 T:3388957408 NOTICE: Opening stream: 0 source: 256
2019-05-16 20:25:01.344 T:3388957408 NOTICE: Whitelist search for: width: 1280, height: 720, fps: 23.976, 3D: false
2019-05-16 20:25:01.346 T:3388957408 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (28) (weight: 0.000)
2019-05-16 20:25:01.381 T:4070367232 NOTICE: VideoPlayer: OnLostDisplay received
2019-05-16 20:25:01.382 T:4070367232 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2019-05-16 20:25:01.382 T:4070367232 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2019-05-16 20:25:01.675 T:3388957408 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
2019-05-16 20:25:01.681 T:3388957408 NOTICE: Creating video thread
2019-05-16 20:25:01.681 T:3291423456 NOTICE: running thread: video_thread
2019-05-16 20:25:01.731 T:3388957408 NOTICE: Opening stream: 1 source: 256
I tried 4 times and got 4 crashes. I’m using PlexKodiConnect and playing a file from a PMS. File is H.264/DD+ and I use audio passthrough.
Thankfully I had recorded in my backhistory the changes it made in the upgrade so I reverted back by removing the entry in the sources.list and then
apt install mediacenter-addon-osmc=3.0.671 armv7-libsqlite-osmc=3.21.0-2 vero3-mediacenter-osmc=18.2.0-6 armv7-eventlircd-osmc=1.3.4
apt purge ir-keytable
File plays just fine after this.
I’d need to see a full debug log to have an idea what the issue is.
With any luck other users experience this problem and can provide this.
Installed the update. Looks like I’m having the same issue with Kodi crashing now on starting any file playback. Ugh.
Just reverted using the above help. Hopefully Sam can solve this one.
You always need to sudo when using apt.
Gah you just beat me to it. I was able to sudo. Thanks.
Sam, you may want to remove that update since it breaks Kodi playback completely.
It’s in a development repository – not released to the stable repo.
