Can you try upgrading now and see if this is fixed?
I will when I am back home from work. I will let you know
Thanks.
You will need to reboot after the upgrade.
ok
I can confirm that the latest update solved the proplem. Well done!
Would you share some information what caused this error?
An incompatible codec. We believe this affected only h264. If any other issues, let us know.
