Vero 4K+ won’t connect to any repository
Hi, my OSMC Vero 4K+ just won’t connect to any repository except for the default kodi repo, I’ve tried many and get the same error “could not connect to repository”
It’s doing my head in now, I just can’t find a solution. I can connect to any of the repo urls from a browser so they’re not blocked.
In the log there lots of errors like “Error opening https://raw.githubusercontent.com/…” (different for each repo) but again I can connect to these urls from a browser without any issue.
Any suggestions ? Thanks.
Thanks , I’ve done that now and the log file has been uploaded. The url provided is https://paste.osmc.tv/-removed-
I have exactly the same kodi configuration running on 4 different devices and the Vero4K is the only one giving this error.
Thanks.
This might be part of the issue
2020-10-07 11:48:32.793 T:3791917792 DEBUG: DEPRECATION: The OpenSSL being used by this python install (OpenSSL 1.1.0l 10 Sep 2019) does not meet the minimum supported version (>= OpenSSL 1.1.1) in order to support TLS 1.3 required by Cloudflare, You may encounter an unexpected reCaptcha or cloudflare 1020 blocks.
But further than that we can not support/discuss this on this forum due to our piracy rules.
https://discourse.osmc.tv/faq#piracy
Thanks, I appreciate that but my issue is not piracy related. It happens with every repository I’ve tried.
I assume the OpenSSL being used by this python install is part of the osmc/kodi build ? My device says there are no updates available. Is it possible for me to update the OpenSSL ?
Thanks for your help.
Well the two repositories that you have installed are both falling in the “no support” category. Can you reproduce with a legal Repo? E.g. Index of /repository/
It will be updated automatically with the next major update for Buster which should come in the next 2 weeks.
Ok thanks, I’ll try that.
OK great thanks for your help.
OK, I’ve upgraded my Vero box to the latest Buster build and removed all “pirate” sources. I’ve installed the yatse repo and I’m getting the same error when trying to use it “Could not connect to repository”
I’ve uploaded a new log file [here]
I can see in the log that it’s just failing to reach the url like my first post…
ERROR: Open - Error opening https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
I can access this url no problem from any browser and have no issue with repos on other kodi boxes, I’m baffled!
Connect via SSH to the Vero and run wget https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5 and check what happens
osmc@osmc-vero4k:~$ wget https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
–2020-10-07 15:43:36-- https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 199.232.24.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|199.232.24.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 32 [text/plain]
Saving to: ‘addons.xml.md5’
addons.xml.md5
100%[==========================================================================================================>] 32 --.-KB/s in 0s
2020-10-07 15:43:37 (161 KB/s) - ‘addons.xml.md5’ saved [32/32]
no issues that way it seems
Well then something must be going wrong within Kodi.
Maybe try to enable debug logging in Kodi and then upload the logs again after trying the Repository maybe that gives more details what goes wrong.
Yes that’s what I done and posted the log in my last post, anyway thanks for all your help.
Nope, you didn’t enable debug logging.
Oh sorry, I must of disabled it again.
New log file [here]
Well you get a unhandled exception thrown which is still strange. I just tried the Yatse Repo on my system and don’t get an issue.
2020-10-07 16:35:28.335 T:3918524640   ERROR: Open - Unhandled exception
2020-10-07 16:35:28.335 T:3918524640   ERROR: Open - Error opening https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
Last test that comes up my mind try curl on command line
curl https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
yes that works no problem and retrieves the md5
osmc@osmc-vero4k:~$ curl https://raw.githubusercontent.com/Tolriq/repository.yatse.kodi/master/zips/addons.xml.md5
47f024802e7044cd5c3e686a5cb55f56osmc@osmc-vero4k:~$
The osmc repo and standard kodi repo work, it’s all a bit odd.
Yeah I am out of ideas other than Kodi is damaged
I’ve got to the bottom of it after a day of debugging and googling.
I had an incorrect setting in my advancedsettings.xml for increasing the video cache. I had the wrong number in there and was asking for more ram than the device has. After a lot of googling I came across this thread on the kodi forums that helped me solve it. I’ve changed the memorysize number and it’s all working now.
Thanks a million for all your help.
