Vero 4K won't update / reinstall
My VERO 4K is still running the ‘November 2020 2020.11-1’ image.
via the OSMC menu searching for a update it doesn’t find one.
Then I thought let’s try to re-install it, dropping the image on a USB drive, but that doesn’t sees it.
What is going wrong ?
Regards,
Bernd
Check out the hotfix in Q1 of the FAQ that should get you going.
