I don’t think mine is NAS related, nothing has changed there for 4 years. It looks to be losing WiFi, hence why log uploads didn’t work.
I’ve been setting up a Ubiquiti Unifi AP specifically for streaming so if nothing is clear in the logs tomorrow I’ll try the Vero on that.
Ah ok.
Mine would lose connection - Never had the issue on other Media players I own. This rectified my issue - sorry it doesn’t help you.
Thought i’d check anyway, is this where you mean? I don’t connect with permissions so would fall under the ‘Everyone’ permission.
Here’s the kernel log
https://paste.osmc.tv/kiqodefoda
The full log is saying that it’s too large, is there another way to get it?
osmc@osmc:~$ sudo journalctl -b -1 --no-pager|paste-log
Unable to upload log. Log file is too large. (117MB)
Well you can pipe it into a file sudo journalctl -b -1 --no-pager >> log_upload.txt
And then share the file via dropbox or similar.
Alternative filter for wlan.
sudo journalctl -b -1 --no-pager | grep -i wlan | paste-log
https://paste.osmc.tv/urujenetog
Not much in there, I’ll do the full log
That’s odd if it is the complete previous log then their should be much more wlan lines (like assigning the IP).
But times are not adding up anyhow.
But one thing I saw is which is a de-authentication request
Feb 18 03:50:54 osmc kernel: CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH
I’ve got this into a txt file and had a look at it, all it contains is 1000’s of lines of the following up until I rebooted it
Feb 18 09:01:10 osmc connmand[330]: ipconfig state 7 ipconfig method 1
Feb 18 09:01:10 osmc connmand[330]: ipconfig state 2 ipconfig method 1
then
Feb 18 09:01:14 osmc systemd-logind[301]: System is rebooting.
Feb 18 09:01:15 osmc systemd[1]: Stopping Authorization Manager...
Feb 18 09:01:15 osmc systemd[1]: Stopped target RPC Port Mapper.
Feb 18 09:01:15 osmc systemd[1]: Stopping Vero3 Bluetooth support...
Feb 18 09:01:15 osmc systemd[1]: Stopped target Bluetooth.
Feb 18 09:01:15 osmc systemd[1]: Stopped target Timers.
Feb 18 09:01:15 osmc bluetoothd[942]: Terminating
Feb 18 09:01:15 osmc systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Feb 18 09:01:15 osmc bluetoothd[942]: Failed to set mode: Invalid Index (0x11)
Feb 18 09:01:15 osmc systemd[1]: Stopped target System Time Synchronized.
Feb 18 09:01:15 osmc systemd[1]: Reached target Unmount All Filesystems.
Feb 18 09:01:15 osmc systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 18 09:01:15 osmc systemd[1]: Stopped Timer to report anonymous OSMC install statistics.
Feb 18 09:01:15 osmc systemd[1]: Stopping Bluetooth service...
Feb 18 09:01:15 osmc systemd[1]: Unmounting RPC Pipe File System...
Feb 18 09:01:15 osmc systemd[1]: Stopping Disk Manager (legacy version)...
Feb 18 09:01:15 osmc systemd[1]: Stopping lircd remote support...
Feb 18 09:01:15 osmc systemd[1]: Stopping NFS status monitor for NFSv2/3 locking....
Feb 18 09:01:15 osmc systemd[1]: Stopped target Sound Card.
Feb 18 09:01:15 osmc sshd[449]: Received signal 15; terminating.
Feb 18 09:01:15 osmc systemd[1]: Stopped target Graphical Interface.
Feb 18 09:01:15 osmc avahi-daemon[303]: Got SIGTERM, quitting.
Feb 18 09:01:15 osmc systemd[1]: Stopped target Multi-User System.
Feb 18 09:01:15 osmc avahi-daemon[303]: avahi-daemon 0.6.32 exiting.
Feb 18 09:01:15 osmc systemd[1]: Stopping LSB: Start NTP daemon...
Feb 18 09:01:15 osmc systemd[1]: Stopped target Login Prompts.
Feb 18 09:01:15 osmc systemd[1]: Stopping Serial Getty on ttyS0...
Feb 18 09:01:15 osmc systemd[1]: Stopped OpenVPN service.
Feb 18 09:01:15 osmc systemd[1]: Stopping Automounts filesystems on demand...
Feb 18 09:01:15 osmc dbus[305]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service'
Feb 18 09:01:15 osmc systemd[1]: Stopping mount disks automatically with standby...
Feb 18 09:01:15 osmc systemd[1]: Stopping Login Service...
Feb 18 09:01:15 osmc systemd[1]: Stopped Improves system performance tunables.
Feb 18 09:01:15 osmc systemd[1]: performance.service: Unit entered failed state.
Feb 18 09:01:15 osmc systemd[1]: performance.service: Failed with result 'exit-code'.
Feb 18 09:01:15 osmc systemd[1]: Stopped Setup OSMC machine ID.
Feb 18 09:01:15 osmc systemd[1]: Stopping OpenBSD Secure Shell server...
Feb 18 09:01:15 osmc systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Feb 18 09:01:15 osmc systemd[1]: Stopping media center application...
Feb 18 09:01:15 osmc systemd[1]: Stopped Login Service.
Feb 18 09:01:15 osmc systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Feb 18 09:01:15 osmc kernel: meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
Feb 18 09:01:15 osmc systemd[1]: Stopped OpenBSD Secure Shell server.
Feb 18 09:01:15 osmc systemd[1]: Stopped mount disks automatically with standby.
Feb 18 09:01:15 osmc systemd[1]: Stopped Disk Manager (legacy version).
Feb 18 09:01:15 osmc systemd[1]: Stopped Authorization Manager.
Feb 18 09:01:15 osmc systemd[1]: Stopped Serial Getty on ttyS0.
Feb 18 09:01:15 osmc systemd[1]: Stopped NFS status monitor for NFSv2/3 locking..
Feb 18 09:01:15 osmc dbus[305]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Refusing activation, D-Bus is shutting down.
Feb 18 09:01:15 osmc systemd[1]: Stopped target Host and Network Name Lookups.
Feb 18 09:01:15 osmc systemd[1]: Stopping Permit User Sessions...
Feb 18 09:01:15 osmc systemd[1]: Removed slice system-serial\x2dgetty.slice.
Feb 18 09:01:15 osmc systemd[1]: Stopped /etc/rc.local Compatibility.
Feb 18 09:01:15 osmc systemd[1]: Unmounted RPC Pipe File System.
Feb 18 09:01:15 osmc systemd[1]: Stopped Permit User Sessions.
Feb 18 09:01:15 osmc kernel: Bluetooth: hci0 sending frame failed
Feb 18 09:01:15 osmc systemd[1]: Stopped Automounts filesystems on demand.
Feb 18 09:01:15 osmc systemd[1]: Stopped lircd remote support.
Feb 18 09:01:15 osmc systemd[1]: Removed slice system-lircd_helper.slice.
Feb 18 09:01:15 osmc ntpd[919]: ntpd exiting on signal 15 (Terminated)
Feb 18 09:01:15 osmc ntp[11717]: Stopping NTP server: ntpd.
Feb 18 09:01:15 osmc systemd[1]: Stopped LSB: Start NTP daemon.
Feb 18 09:01:17 osmc bluetoothd[942]: Stopping SDP server
Feb 18 09:01:17 osmc bluetoothd[942]: Exit
Feb 18 09:01:17 osmc systemd[1]: Stopped Vero3 Bluetooth support.
Feb 18 09:01:17 osmc systemd[1]: Stopped Bluetooth service.
Feb 18 09:01:19 osmc sudo[836]: pam_unix(sudo:session): session closed for user osmc
Feb 18 09:01:19 osmc kernel: Console: switching to colour frame buffer device 240x67
Feb 18 09:01:19 osmc systemd[1]: Stopped media center application.
Feb 18 09:01:19 osmc systemd[1]: Stopped target Network is Online.
Feb 18 09:01:19 osmc systemd[1]: Stopped target Network.
Feb 18 09:01:19 osmc systemd[1]: Stopped target Remote File Systems.
Feb 18 09:01:19 osmc systemd[1]: Stopped target Remote File Systems (Pre).
Feb 18 09:01:19 osmc connmand[330]: Terminating
Feb 18 09:01:19 osmc systemd[1]: Stopped target NFS client services.
Feb 18 09:01:19 osmc systemd[1]: Stopping Connman connection service...
Feb 18 09:01:19 osmc systemd[1]: Stopping eventlircd remote support...
Feb 18 09:01:19 osmc wpa_supplicant[446]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Feb 18 09:01:20 osmc connmand[330]: Remove interface eth0 [ ethernet ]
Feb 18 09:01:20 osmc connmand[330]: Remove interface wlan0 [ wifi ]
Feb 18 09:01:20 osmc connmand[330]: eth0 {remove} index 2
Feb 18 09:01:20 osmc connmand[330]: wlan0 {remove} index 3
Feb 18 09:01:20 osmc connmand[330]: Exit
Feb 18 09:01:20 osmc kernel: [35B blob data]
Feb 18 09:01:20 osmc kernel: P2P interface stopped
Feb 18 09:01:20 osmc kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 18 09:01:20 osmc kernel: P2P interface unregistered
Feb 18 09:01:20 osmc wpa_supplicant[446]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Feb 18 09:01:20 osmc systemd[1]: Stopped eventlircd remote support.
Feb 18 09:01:22 osmc systemd[1]: Stopped Connman connection service.
Feb 18 09:01:22 osmc systemd[1]: Stopping WPA supplicant...
Feb 18 09:01:22 osmc systemd[1]: Stopped WPA supplicant.
Feb 18 09:01:22 osmc systemd[1]: Stopping D-Bus System Message Bus...
Feb 18 09:01:22 osmc systemd[1]: Stopped D-Bus System Message Bus.
Feb 18 09:01:22 osmc systemd[1]: Failed to propagate agent release message: Connection reset by peer
Feb 18 09:01:22 osmc systemd[1]: Stopped target Basic System.
Feb 18 09:01:22 osmc systemd[1]: Stopped target Paths.
Feb 18 09:01:22 osmc systemd[1]: Stopped sdio device path monitor.
Feb 18 09:01:22 osmc systemd[1]: Stopped target Sockets.
Feb 18 09:01:22 osmc systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Feb 18 09:01:22 osmc systemd[1]: Stopped target Slices.
Feb 18 09:01:22 osmc systemd[1]: Removed slice User and Session Slice.
Feb 18 09:01:22 osmc systemd[1]: Closed D-Bus System Message Bus Socket.
Feb 18 09:01:22 osmc systemd[1]: Stopped target System Initialization.
Feb 18 09:01:22 osmc systemd[1]: Stopped Apply Kernel Variables.
Feb 18 09:01:22 osmc systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Feb 18 09:01:22 osmc systemd[1]: Stopped Load Kernel Modules.
Feb 18 09:01:22 osmc systemd[1]: Stopping Restore / save the current clock...
Feb 18 09:01:22 osmc systemd[1]: Stopped target Swap.
Feb 18 09:01:22 osmc systemd[1]: Stopping Load/Save Random Seed...
Feb 18 09:01:22 osmc systemd[1]: Stopped target Encrypted Volumes.
Feb 18 09:01:22 osmc systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Feb 18 09:01:22 osmc systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Feb 18 09:01:22 osmc systemd[1]: Stopped Restore / save the current clock.
Feb 18 09:01:22 osmc systemd[1]: Stopped Load/Save Random Seed.
Feb 18 09:01:22 osmc systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Feb 18 09:01:22 osmc systemd[1]: Stopped Create Volatile Files and Directories.
Feb 18 09:01:22 osmc systemd[1]: Stopped target Local File Systems.
Feb 18 09:01:22 osmc systemd[1]: Stopped target Local File Systems (Pre).
Feb 18 09:01:22 osmc systemd[1]: Stopped Create Static Device Nodes in /dev.
Feb 18 09:01:22 osmc systemd[1]: Stopped Remount Root and Kernel File Systems.
Feb 18 09:01:22 osmc systemd[1]: Reached target Shutdown.
Feb 18 09:01:22 osmc systemd[1]: Reached target Final Step.
Feb 18 09:01:22 osmc systemd[1]: Starting Reboot...
Feb 18 09:01:22 osmc systemd[1]: Shutting down.
Feb 18 09:01:22 osmc systemd-journald[167]: Journal stopped
Well we need to figure out what happen before that.
Can you check what sudo journalctl | grep -i wlan | paste-log generates?
Ah sorry that only is the current log, try
journalctl --since yesterday | grep -i wlan | paste-log
https://paste.osmc.tv/zelixiqequ
Looks like the same time-frame though
Sorry I am not that expert of journalctl, guess the below one will work
journalctl -b -1 | grep -i wlan | paste-log
journalctl -b -2 | grep -i wlan | paste-log
same as posted above, not much in there
https://paste.osmc.tv/uxazolareb
I’ve set Vero up on my Unifi AP, I’ll see how that goes. The AP Vero was using is a Sky Q mesh. I know Sky often send firmware updates overnight so that may be causing issues.
NemoN
19 February 2020 14:33
37
i have the same problem, with the latest update the LAN attached vero4k+ looses network connection after some hours (reboot reconnect the box). i will try to upload a log.
Well not much in there
[37652.373585] wl_iw_event: Link Down with BSSID=78:3E:53:CF:80:63
[37652.373640] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[37652.373650] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=1 from 78:3e:53:cf:80:63
[37652.374653] wl_iw_event: Link Down with BSSID=78:3E:53:CF:80:63
[37652.374709] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[37652.377294] cfg80211: Calling CRDA for country: GB
[37656.210592] Connectting with 90:21:06:87:a0:e5 channel (36) ssid "BillyTheBroadband", len (17)
[37656.286879] wl_iw_event: Link UP with BSSID=90:21:06:87:A0:E5
[37656.286915] wl_bss_connect_done succeeded with 90:21:06:87:a0:e5
[37656.343375] wl_bss_connect_done succeeded with 90:21:06:87:a0:e5
[37758.928407] Connectting with 78:3e:53:cf:80:66 channel (1) ssid "BillyTheBroadband", len (17)
[37758.991220] wl_iw_event: Link UP with BSSID=78:3E:53:CF:80:66
[37758.991257] wl_bss_connect_done succeeded with 78:3e:53:cf:80:66
[37758.998686] wl_bss_connect_done succeeded with 78:3e:53:cf:80:66
[37759.081740] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[37759.083215] wl_iw_event: Link Down with BSSID=78:3E:53:CF:80:66
[37759.083275] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[37759.083285] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 78:3e:53:cf:80:66
[37856.509371] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH
[37856.510952] CFG80211-ERROR) wl_escan_handler : escan is not ready ndev ffffffc05c43d800 drv_status 0x0 e_type 69 e_states 4
[37856.514560] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH
[37856.517052] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH
[37856.526019] CFG80211-ERROR) wl_escan_handler : WLC_E_STATUS_NEWSCAN : scan_request[ffffffc05e20cc00]
[37856.526034] CFG80211-ERROR) wl_escan_handler : sync_id[4660], bss_count[0]
[37856.539853] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH
[37856.541100] CFG80211-ERROR) wl_escan_handler : escan is not ready ndev ffffffc05c43d800 drv_status 0x0 e_type 69 e_states 4
[63509.845238] hdmitx: system: irq 80000002
Maybe if you connect it to your UniFi network you can check the UniFi logs to see why it disconnects.
Only other alternative might be to try a reinstall
Yeah, will do a reinstall, thanks for you help
This seems quite similar to this thread Losing WIFI Signal after a while
Unfortunately, there was no resolution to the thread and it looked like either an AP-specific or environmental issue.
