I considered that – usually it’s the few variables I can’t test before dispatch.
Can only test a few plugs and there are additional variations like voltage in the UK.
All WiFi modules for Vero V are Realtek RTL8822CS. It’s a known and widely used 802.11ac module. We have been using them in test units since 2019 (RTL8822BS) module and the CS module since 2020. But we have limited WiFi equipment to test with.
What I did find last night is that I can make the Vero V crash on WiFi with minimal traffic (also slow to type on SSH) if I enable:
Daily channel optimisation
Set band steering to ‘Prefer 5Ghz’
I am waiting for the next crash (likely when Unifi does optimisation) to work out why. After the crash, I couldn’t connect any iPhone to the network either, but my laptop was working fine.
My only info was from using Wireshark’s OUI lookup tool which shows China Dragon Technology as the manufacturer. The wifi in the 4k+'s is from AMPAK Technology.
The module is from Realtek. WiFi firmware and driver is also from Realtek.
It’s Broadcom AP6255/6256 SoC.
We looked at newer Broadcom WiFi modules, but the performance was very poor compared to Realtek and there were other issues. We also explored AMLogic’s W1 solution, but that’s a disaster in terms of driver and designed specifically for Android use.
I didn’t jump through any hoops to get it to crash - just playing UHD.
I never lost any network access with my other gear during a Vero V freeze but the Vero’s are on their own vlan so if it did something to affect traffic on that vlan I would not have noticed.
I appreciate that, really do. This is not the kind of experience I want to give you, particularly as a loyal customer!
Give it a few days and it will be solved one way or another.
You reported this in November 2023 (please do give us credit that you disappeared for a while regarding this topic) so hopefully those extra few days don’t matter if it is solved properly.
Same applies for everyone else that has posted here
According to the OUI, China Dragon is the fabricator of the Realtek device that was in my unit. Seems Realtek uses many fabicators to produce their devices.
I did snooze on the followup as UHD wasn’t that important to me at the time, and when I went back to looking into it was hoping some upgrades in the meantime had fixed it.
No worries, you get a lot of credit. Thank you for your help and hard work!
I haven’t seen any fixes. It’s still an issue. There was some mention of moving from Debian Bulleye to Debian Bookworm with a later kernel but so far that hasn’t happened. Pretty much gave up on it myself, went to sneakernet for UHD playback. That was one thing the Vero 4 did better than the Vero V.
@sam_nazarko i can reproduce it daily in fact im stuck using an old router ( that at some point i have to decommission ) just so that i can use the Vero V
Are there any WIFI USB adapters that have modules in the current Vero V kernel that we can use instead of the built in one ?
I can confirm that the problem still exists.
I have been running the Vero V on ethernet because of this issue, and when this thread came up again, i tried switching to WiFi again, and sure enough the problem is still there.
Yes i am.
My AP is a UAP 6 Pro, I have band steering set to off, and manually configured the channels in unifi, not using any form of channel AI or channel optimization.
But not a big deal for me, as i have switched to ethernet.
